Prahjister ROM 1.0 MK808(B) 2/8/14 4.2.2
Thank you
If everything works and no changes i will update all the apps and make a cleaner install with 1 or 2 files to download. I have been using is steady for a couple days with no re flashing....i'm pretty happy.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by prahjister View PostI am curious to know if anyone is using this rom as there daily?
Only downer I can spot is VNC server doesn't work properly ... I can't click reliably ( mostly not at all ).
I can't say, but this is probably an issue on all ROMs ( maybe not the older 4.1 ones )
The jury is still out on XBMC too ... my CPU utilization still seems high when streaming 720p content ( shouldn't it be pretty much flat? )
I did not flash libstagefright, but I copied it using root explorer.
But this rom for mk808B wifi ok and not BT in setting????
mk808B have rk903 chip
mk808 have rk901chip
wifi mk808 not good for mk808B, so you have used a setting.apk for mk808 and not for B version.
good rom but mk808B without BT useless for me......
Can i flash file for test BT??
SOLVED with RkSettingLast edited by Mandrake2; 22 February 2014, 00:19.
Originally posted by slcpunk View Post+1, although I only use my MK808 maybe every few days.
Using the 2dark4u kernel at 1.4ghz performance, I will get a usage of around 70% for the first 5mins, then it will drop to around 20-50% after.Currently Using:
2 x Nvidia Shield TV | MiniMX III
Retired Devices:
MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
Originally posted by ididmytime View PostThe high CPU load could be due to scalling, unless the restrictions have been lifted from stock kernel, it will scale to only 1ghz most of the time unless set to performance.
Originally posted by Sc0rp10 View Posti thought 2dark4u kernels were only for 4.1 roms. can you post the one you're using? thanks.
The stock kernels are a mess, even running it through a partially working overclocking program like rkpatchomatic I'm not sure if the restrictions get lifted. GPU/DDR overclocking is definitely broken however.Currently Using:
Retired Devices:
Originally posted by givecredit View PostDoes the rom flashed version already include the latest libstagefright? If not how do I install libstagefright.?Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
There are currently 1832 users online. 0 members and 1832 guests.
