Prahjister ROM 1.0 MK808(B) 2/8/14 4.2.2
    Ynt: Prahjister ROM 1.0 MK808(B) 2/8/14 4.2.2
    Im trying to download libstagefright update but bunch of files pops up to download in google drive how am i going to flash those files its not zip.
    GT-N7000...
      GT-N7000...
      There is a "File" menu in the top-left corner. Go there, and you'll see "Download" link.
        Thanks i downloaded.
        GT-N7000...
          Is updating libstagefright only for xbmc or it has another benefits also?
          GT-N7000...
            GT-N7000...
            its the only reson that i know of
              Gonna take the plunge tonight with your 1.0 rom + 1080p kernel.
              Any updates how the 1.1 rom is coming along?
                its basically the same with cron and init.d enabled....its all working...i wil have several scripts preloaded...i just dont know what to add...i would add some bluetooth stuff but i have no way of testing...it will be a flash install...update cwm...then flash busybox symlink....not so many steps to get going...
                I changed it to look like a nexus 7 because netflix is supposed to be hd.
                i would like to add oc kernels because 1080 is just as fast as 720 but i dont want to hear people say it doesnt work. Need a good power supply as well.
                  1) Sorry, if there are any grammar mistakes - i am not a native speaking
                  2) Are there any experience with a modded MK808B with copper heat-sinks using the unstable overclocked kernel? Will it probably stable? Cause - i've already bought some copper heat-sinks, just needing a reason to install them :P
                  3) Is the AP6210 BT and Wifi Module working on this rom?
                  Kind regards
                  eve_Snuffy
                  Kind regards Snuffy
                    Kind regards
                    eve_Snuffy
                    The kernel should work fine...Cooling should help...best thing is to have a good power supply and a good usb cable....i might try to take a usb cable apart and see if i can replace with a thicker guage wire...and report back.
                      I have a mk808b with a modded heat sink (from a pentium 2) and clocks that reach 1,6 ghz are not stable for me. My conclusion is that the stability is determined by other factors.
                      Sent from my GT-I9100 using Tapatalk
                        Thanks then no need to update for me.
                        I run my device 1500 ghz locked performance mode and i get very good performance and it gets 13660 max antutu. Only thing i dont like is GPU speed i really dont understand why mk 808 can overclock gpu and why mk808b not. Im sure this device easily hits 14500 pts antutu if run 400 hz GPU. This is how i cool it it runs ice cold even on hardest tasks.
                        GT-N7000...
                          Are you able to release 1.1 version with oc 1080p kernel and additional scripts? Unfortunatelly version 1.0 on my MK808 cant boot again after first booting, I hope 1.1 will can...
                            OK tonight i took apart a spare usb cable and cut it down to just the ends. I took one pair of some cat 6 cable i had laying around and replaced the stranded in the usb...i did some research and you have to remove the twist. soldered it to the ends on appropriate pins...the standard type a side was easy....the mini side was more difficlut. im not the best at soldering so i wasnt too clean and i just broke the pins i wasnt using off....it runs just as good as my factory 4" cable and twice as long. I had to insulate where i soldered on the mini so it would not touch the metal part on the outside...looks like crap...i had to use electrical tape i didnt have any skrink tube or else i could have had a more professional look.
                              Cheers mate
                              wow nice rom thankyou for your hard work, will run it for a while and see how it goes, just using it for xbmc really, but great so far. cheers
                                Hey guys.
                                Maybe a stupid question but how do i add widgets into the home screen?(ie weather widget)
                                Also bluetooth seems to be disabled, i can see it in the notification status its grayed out.
                                But i cant find the way to enable it.
                                I flashed through CWM.
                                Are these matters fixed in v.1.1?
                                Thnx in advance.
