Pipo M6 Pro RileyROM 1.8 KitKat
I just tested that one on my P9 and it works very well.
Sent from my P9Randy
Originally posted by rrileypm View PostHave you tried this new ROM the Freaktab Team compiled from Pipo Sources?
http://www.freaktab.com/showthread.p...Project-M6-Pro
Here is a CWM template you can use to build your own. Just follow the instructions in the txt file.
Randy
https://drive.google.com/file/d/0Byx...ew?usp=sharing
What else ?
I tried it and installtion aborted in CWM.
It was worth a try. I guess this template won't work for some reason. Maybe it's not compatible with your version of CWM.
Are you not able to flash the ROM from your PC?Randy
Is there any known way to flash rom from TWRP 2.7.0.0? I messed things up hard
CWM template above gives me error when trying to flash:
assert failed: getprop ("ro.product.device") == "rk3066" || getprop("ro.product.device") == "rk30sdk"
E: Error executing updater binary in zip
Error flashing zip
My PC does recognize tab in flash mode, but neither rom_flash_tool nor rkbatchtool can detect it :/
System is Windows7x64, drivers installed are rockchip 3.5 date 12.3.2013.
edit: OK so I found
and managed to flash system, boot and kernel with this template in TWRP.
Tablet now boots to Android, but flash tools still can't see it, and tips? I plan to flash stock pipo ROM cause I have to to send the tab to service (screen glitches, stil present with new rom) and it is still under warranty.
edit2: by using this modification to Rockchip Batch Tool
the RBT 1.7 now detects tablet and manages to do the "switch". However Finless Rom Flash Tool still says "No Found RKAndroid rock usb"
Edit3: This usb 1.1 trick
helped me so I can now flash RileyRom tooLast edited by filip21; 20 January 2015, 14:02.
Hi i have a pipo m6 pro wifi i have use your 1,7 kitkat rom for almost 1 year whit out any problem, until yesterday when my tablet stuck on CWM-based recovery, i try to flash new rom whit flashtool but the program dont find the tad i follow instruction about drivers so i decied to flash with zip on external card the problem is when i go to wipe data/factory reset the tablet stuck and i need to do reset, wipe cache partition done ok. So far ok when i go to install rom whith zip in external sd card shows me : "boot.img installed" , kernel.img installed and installing system.img this will take a few minutes* is stuck there for hours whats going rong what do rong please help no money yo duy new tablet, i try and the new rom but nothing always stuck on system.img this will take a few minutes i need to do reset from back to go again on cwm menu
You really need to solve the problem flashing from your PC.
Is it the same PC you flashed the tablet with previously? If so, the drivers should have been already loaded.
1. Windows 8.1 won't work...you need an earlier version of Windows.
2. Use a USB 2.0 port...not USB 3.0.
3. Use the USB cable that came with the tablet...it has a longer micro plug to fit better into the tablet.
Erase IDB and install the whole ROM. It's important to flash stock recovery when you flash so all of the partitions will be formatted correctly.
There is a newer version of the ROM that fixed several things Pipo left undone when they discontinued support. http://www.freaktab.com/showthread.p...Project-M6-ProRandy
[QUOTE=rrileypm;275592]You really need to solve the problem flashing from your PC.
There is a newer version of the ROM that fixed several things Pipo left undone when they discontinued support. http://www.freaktab.com/showthread.p...Project-M6-Pro[/QUOTE
Ι install the drivers on another pc with vista but still nothing, flash tool not found the tab.
the tab is stuck on CWM recovery screen, does it matters??
it shows in cwm recovery E:can't mount/cache/recovery/log
E:can't open/cache/recovery/log
>>>>>>>>>>>>>>>>>>>>/last_logLast edited by lakiskir; 25 January 2015, 20:23.
Originally posted by lakiskir View PostI try also to wipe data factory reset but again it stucks on
wiping bata....
Formating/ data...
Formating/cache....
it doesnt do anything until i reset it from the back and again goes me in cwm recovery menu
Please help i stuck on cwm menu i dont know what to do i try 3 pcs but the computer finds the tab but not the flashtool i install the drives please help is any change to to restore some how with cwm, i dont know what to do....
There are currently 3517 users online. 0 members and 3517 guests.
