Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by FatFreddyDK View Postif you appreciate my efforts this is the link for any donation:
Originally posted by FatFreddyDK View PostI am having a few reboots every ones in a while, not often but maybe ones ot two a week. Im running 1.8.2 with default kernel. Any chance that one of the modded kernel would help on that problem?
As i understand it there is no need for changing the libril file on 1.8.2?
With modded kernel you will have: deep sleep working, if you have a 3G model, and better battery duration.
About stability, you can try by yourself, you can always revert back on stock kernel without losing any data!if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View Postyes, libril on 1.8.1 and 1.8.2 is the stock (the correct one).
Originally posted by FatFreddyDK View PostI have m6 pro 16gb wifi. What is the difference between stock kernel and target 2.1 and 825 users kernel?
The differences between the kernels are linked to the cpu voltages: with lower voltage the battery lasts loger, but if you do not have a lucky cpu you can have an unstable tablet. To know if you have a lucky cpu the only way is try the kernel and see!if you appreciate my efforts this is the link for any donation:
Originally posted by serhiy2000 View PostWhere can I find it? There is no sign of it in the header.
I have flashed to Rileyrom 1.8. Is it necessary to rewrite libril also, before flashing kernel? I have compared filesize = both files are the same size in my tab and from the site.
Originally posted by serhiy2000 View PostI have flashed to Rileyrom 1.8. Is it necessary to rewrite libril also, before flashing kernel? I have compared filesize = both files are the same size in my tab and from the site.
1.8.1 and 1.8.2 already have the correct libril (stock kitkat one)if you appreciate my efforts this is the link for any donation:
Thanks for the tip.Randy
Originally posted by panava View PostAnyone having problems with game freezing, ie Boom beach etc. Here's the solution I found on another forum. Tick “Disable HW overlays” under the Developer options in settings andgames work fine.if you appreciate my efforts this is the link for any donation:
good job, tablet running as it should
Hello
After struggling 4 hours with windows 8.1 trying to connect with the rockchip drivers, I got back my vostro with windows vista, and flashed the ROM in less then 10 mins. with 12 mgb for the internal space (no more wory moving apps to SD)
My laptop with windows 8.1 is an amd, did anyone has the same problem with Intel computer?
All tested is running smooth and quick, get back flash with dolphin browser, tested GPS and it works but outside only with GPS fix app.
You can't no more switch the screen resolution (useful only to devloppers?), and how add more tabs to home?
If the reboot app is going to make troubles, can I delete it or is it needed by the system?
Thx for your job, I will keep testing and considerating a donation .
2 - gps has trouble just because the antenna length is too short, keep as it is or you can try replacing the antenna (otherwise you can try one of my modded kernel and see if it can make any difference for you)
3 - switching resolution is no more possible with kitkat
4 - you can delete reboot app without any issueif you appreciate my efforts this is the link for any donation:
There are currently 1728 users online. 1 members and 1727 guests.
