Sent from my M6Pro using Tapatalk
Pipo M6 Pro RileyROM 1.8 KitKat
If that's the case, you may need to install that gapps occasionally to keep them up to date. It sounds like they aren't being saved properly. But this only happens if you have the tablet set in ART.Randy
Re: Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by rrileypm View PostIf that's the case, you may need to install that gapps occasionally to keep them up to date. It sounds like they aren't being saved properly. But this only happens if you have the tablet set in ART.
I don't think their are 68 gapps. While it's possible those 68 apps are not compatible with art, I believe that is highly unlikely.
OK, guys....we will have to think about this one.Randy
Is there any chance you guys are running Xposed Framework?
That could very well be the problem.Randy
I used to, but not now. Before running the tests I mentioned above, 1.8.2 was reflashed clean, including erasing idb.
I had to use the 6gb parameter file to have enough space for all those apps with art. That was when I was getting the 68 apps that needed upgrading. Maybe that is a clue.
But I also tested with the default 4gb parameter file, with a very small number of apps, and it still had a few apps that needed upgrading.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Deep Sleep again
Thank You Randy for your excellent end endless work!
I'd like to know is there a combination of this 1.8.2 Rom + Kernel + libril to have a full working system aI mean Good 3G+strong wi-fi+Deep sleep?
I haven't find solution yet maybe my fault, if i have Deep sleep i have no 3G and vs.
Thank You again!
Originally posted by rruzsi View PostThank You Randy for your excellent end endless work!
Thank You again!
post #749if you appreciate my efforts this is the link for any donation:
Just upgraded... possible screen issue?
I just upgraded my Pipo M6 Pro to the KitKat 4.4.2 RileyROM 1.8.2! WOW! I'm so impressed with the change in performance. I'm actually going to keep my Pipo now! Thanks guys!
I do have an issue with QuickOffice. It opens fast to the app, but as soon as I tap Open File, the app crashes.
Also, I can open WPS Office fine, but when I open a Word doc, the top third of the doc only (not the bottom two thirds or the menus at the top) starts to scroll to the right of the screen??
Any ideas if changing a Kernel might help. I had the Very Low Voltage 2.0 kernel installed, until I discovered this problem. I reflashed the original kernel and tried a few others, but problem still persists.
Any help would be appreciated!
Thanks!
Originally posted by smokva View PostFirst of all thanks for this great rom. My m6 pro was slow and sluggish with jelly bean roms. Now it works fast....great!
But i have noticed that camera isnt working on 1.8 rom. To be honest it didnt work on 1.6 rom on my tablet toi.
Originally posted by smokva View PostWhen i try to turn the integrated camera app on it says: "Camera error - Can't connect to the camera".
Everything was working fine with original pipo jelly bean ROM. Than I installed Riley ROM 1.6.1 and it suddenly didn't work. Now I installed 1.8 ROM and it doesn't work again.
I don't use cam on tablet so its not a biggie, but the flash is not working too and I would like to have it as a torch.
Originally posted by Billcnz View PostMost likely a ribbon cable inside needs to be reseated or something and just coincidence it happened when you installed ROM. You could go back to stock if you wanted to check.
Sent from Tapatalk on my m6pro running RR 1.8 KK, kernel low V2
I have the same problem, camera throw's that error when I bring up the app camera. I purchased the Pipo 8 months ago, and I've been with stock ROM since then, and camera it's been working without any issues. I decided to put this Riley ROM yesterday and now it doesn't work.
I don't think it's a coincidence. Something have to do with this, maybe Kernel? maybe different hardware revisions of the same tablet? I don't know ... i'm only talking supositions.
I didnt' use the camera anyway... but I want to post it and let know that smokva is not the only having this issue. Appart of that, I'm glad to use this ROM, the experience is much more gratifying right now
Hi, I'm a new user of your KK-rom. Having a Pipo M6 Pro wifi 32gb since a few months, I was a little disappointed about it's performance. Reading your forum I got interested and installed it a few days ago. Your manual was very good and installation took only a little moment; chapeau!
I was pleasantly surprised about my tablet's new performance. Thanks for this wonderful job.
All seems to work fluently.
One thing which is strange: we use a Medion NAS and when I stream my photos only diagonal coloured stripes apear on the tablet. With the original rom I hadn't this problem.
But over the whole I'm impressed.
You are correct, this ROM will not run on the original M6.Randy
There are currently 2778 users online. 0 members and 2778 guests.
