Στάλθηκε από το HTC One μου χρησιμοποιώντας Tapatalk
Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by fagotistas View PostHello from Greece. I am using this Rom quite a while now. I am having this problem. The tablet goes out randomly about every 2 or 3 days and I have to press the little button on the back , to make it work again. Do you think it is a kernel issue ?
Στάλθηκε από το HTC One μου χρησιμοποιώντας Tapatalkif you appreciate my efforts this is the link for any donation:
Απ: Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by giouncino View Postwhich kernel did you install?
Στάλθηκε από το M6Pro μου χρησιμοποιώντας Tapatalk
Re: Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by fagotistas View PostIt has been a while since I flashed it and I don't remember. I also renamed the kernel file names so in my folder they are as kernel1 , kernel2 etc. I will have to test again and report back. The good thing is , I understand it is a kernel issue.
You can also get it back by pressing and holding the power button for at least 20 seconds, then release and press the power button again until the boot logo comes up.
I've found that rebooting the tablet at least once per day helps. Currently I've got a Tasker routine set up to do it while I sleep.
Sent from my M6Pro using Tapatalk
I thought I would try art again, since most of my apps now claim art compatibility.
I went to developer options and changed the run time to art, it asked me if I wanted to reboot, I said yes, but after it rebooted it didn't regen the art cache.
I looked again in developer options and it still says dalvik . Repeated this two more times, same result.
Has anyone successfully changed from dalvik to art on 1.8.2?
R: Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by Crandy2 View PostI thought I would try art again, since most of my apps now claim art compatibility.
Originally posted by Crandy2 View PostI had uninstalled xposed a couple of weeks ago. So I don't think that's it
I just looked at the logs, and nothing stood out for me.
Do you remember what the error said?
Are you using art now with 1.8.2? I'm pretty sure I enabled it with 1.8.0, but changed back to dalvik because some apps I depend on weren't compatible.
Originally posted by Crandy2 View PostI just looked at the logs, and nothing stood out for me.
08-01 08:31:00.860 120 120 E Xposed : Unsupported runtime library libart.so, setting to libdvm.so
Here it's clear what the problem was... try looking for errors in the first part of the log, when the system starts up... maybe you can find out something similar.
---- 01/ago/2014 08:32:57 ----
--------- beginning of /dev/log/main
08-01 08:30:54.700 123 123 I installd: installd firing up
08-01 08:30:54.730 117 117 I DEBUG : debuggerd: Feb 10 2014 14:09:59
08-01 08:30:54.940 119 119 I SurfaceFlinger: SurfaceFlinger is starting
08-01 08:30:54.940 119 119 I SurfaceFlinger: SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
08-01 08:30:54.980 138 138 I AKMD2 : AK8975/B for Android v 2.0.0.---- (Library: v1.2.0.1217) started.
--------- beginning of /dev/log/system
08-01 08:30:55.160 125 125 E DrmService: ----------------running drmservice---------------
08-01 08:30:55.160 125 125 E DrmService: ----------serianno =OUGRYJSCOM
08-01 08:30:55.160 125 125 E DrmService: auto generate serialno,serialno = OUGRYJSCOM
08-01 08:30:55.160 125 125 E DrmService: drm keybox disable!!
08-01 08:30:55.160 125 125 E DrmService: detect keybox disabled
08-01 08:30:55.320 114 114 E DirectVolume: Vold managed volumes must have auto mount point; ignoring /mnt/internal_sd
08-01 08:30:55.320 114 114 E DirectVolume: Vold managed volumes must have auto mount point; ignoring /mnt/external_sd
08-01 08:30:55.320 114 114 E DirectVolume: Vold managed volumes must have auto mount point; ignoring /mnt/usb_storage
08-01 08:30:55.320 114 114 I Vold : Vold 2.1 (the revenge) firing up
08-01 08:30:55.320 114 114 I Vold : Call notifyStateKernel No.1 in the file of Volume.cpp
08-01 08:30:55.320 114 114 E Vold : Start Misc devices Manager...
08-01 08:30:55.350 114 175 I Vold : Call notifyStateKernel No.1 in the file of Volume.cpp
08-01 08:30:55.360 118 177 I KitKat_RIL_RK_V3.1: Initial var!
08-01 08:30:55.360 114 175 I Vold : Call notifyStateKernel No.1 in the file of Volume.cpp
08-01 08:30:55.400 116 116 I Netd : Netd 1.0 starting
08-01 08:30:55.400 116 116 W InterfaceController: Warning (dlopen failed: library "/system/lib/libnetcmdiface.so" not found) while opening the net interface command library
08-01 08:30:55.670 119 119 I [Gralloc]: using (fd=17)
08-01 08:30:55.670 119 119 I [Gralloc]: id = fb0
08-01 08:30:55.670 119 119 I [Gralloc]: xres = 2048 px
08-01 08:30:55.670 119 119 I [Gralloc]: yres = 1536 px
08-01 08:30:55.670 119 119 I [Gralloc]: xres_virtual = 2048 px
08-01 08:30:55.670 119 119 I [Gralloc]: yres_virtual = 4608 px
08-01 08:30:55.670 119 119 I [Gralloc]: bpp = 32
08-01 08:30:55.670 119 119 I [Gralloc]: r = 16:8
08-01 08:30:55.670 119 119 I [Gralloc]: g = 8:8
08-01 08:30:55.670 119 119 I [Gralloc]: b = 0:8
08-01 08:30:55.670 119 119 I [Gralloc]: format =5
08-01 08:30:55.670 119 119 I [Gralloc]: width = 216 mm (240.829620 dpi)
08-01 08:30:55.670 119 119 I [Gralloc]: height = 135 mm (288.995544 dpi)
08-01 08:30:55.670 119 119 I [Gralloc]: refresh rate = 56.10 Hz
08-01 08:30:55.760 119 119 I SurfaceFlinger: Using composer version 1.3
08-01 08:30:55.760 119 119 W SurfaceFlinger: getting VSYNC period from fb HAL: 17826265
08-01 08:30:55.760 119 119 I SurfaceFlinger: EGL informations:
08-01 08:30:55.760 119 119 I SurfaceFlinger: vendor : Android
08-01 08:30:55.760 119 119 I SurfaceFlinger: version : 1.4 Android META-EGL
08-01 08:30:55.760 119 119 I SurfaceFlinger: extensions: EGL_KHR_get_all_proc_addresses EGL_ANDROID_presentation_time EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_fence_sync EGL_EXT_create_context_robustness EGL_ANDROID_image_native_buffer EGL_ANDROID_recordable
08-01 08:30:55.760 119 119 I SurfaceFlinger: Client API: OpenGL_ES
08-01 08:30:55.760 119 119 I SurfaceFlinger: EGLSurface: 8-8-8-8, config=0x60000014
08-01 08:30:55.760 119 119 I SurfaceFlinger: OpenGL ES informations:
08-01 08:30:55.760 119 119 I SurfaceFlinger: vendor : ARM
08-01 08:30:55.760 119 119 I SurfaceFlinger: renderer : Mali-400 MP
08-01 08:30:55.760 119 119 I SurfaceFlinger: version : OpenGL ES 2.0
08-01 08:30:55.760 119 119 I SurfaceFlinger: extensions: GL_EXT_debug_marker GL_OES_texture_npot GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug
08-01 08:30:55.760 119 119 I SurfaceFlinger: GL_MAX_TEXTURE_SIZE = 4096
08-01 08:30:55.760 119 119 I SurfaceFlinger: GL_MAX_VIEWPORT_DIMS = 4096
08-01 08:30:55.870 122 122 I mediaserver: ServiceManager: 0x41856460
08-01 08:30:55.870 122 122 I AudioFlinger: Using default 3000 mSec as standby time.
08-01 08:30:55.870 122 122 I CameraService: CameraService started (pid=122)
08-01 08:30:55.890 122 122 W linker : librkswscale.so has text relocations. This is wasting memory and is a security risk. Please fix.
08-01 08:30:55.890 122 122 I CameraService: Loaded "RK29_ICS_CameraHal_Module" camera module
08-01 08:30:56.040 122 122 I AudioPolicyManagerBase: loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
08-01 08:30:56.050 122 122 I AudioFlinger: loadHwModule() Loaded primary audio interface from LEGACY Audio HW HAL (audio) handle 1
08-01 08:30:56.050 122 122 I AudioFlinger: HAL output buffer size 1024 frames, normal mix buffer size 1024 frames
08-01 08:30:56.070 122 122 I AudioMixer: found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
08-01 08:30:56.070 122 122 I AudioFlinger: Using module 1 has the primary audio interface
08-01 08:30:56.070 122 346 I AudioFlinger: AudioFlinger's thread 0x41049008 ready to run
08-01 08:30:56.070 122 346 W AudioFlinger: Thread AudioOut_2 cannot connect to the power manager service
08-01 08:30:56.070 122 346 E AudioFlinger: no wake lock to update!
08-01 08:30:56.080 122 122 I audio_a2dp_hw: adev_open: adev_open in A2dp_hw module
08-01 08:30:56.080 122 122 I AudioFlinger: loadHwModule() Loaded a2dp audio interface from A2DP Audio HW HAL (audio) handle 3
08-01 08:30:56.090 122 122 I AudioFlinger: loadHwModule() Loaded alsa_usb audio interface from LEGACY Audio HW HAL (audio) handle 4
08-01 08:30:56.100 122 122 I AudioFlinger: loadHwModule() Loaded usb audio interface from USB audio HW HAL (audio) handle 5
08-01 08:30:56.100 122 122 I r_submix: adev_open(name=audio_hw_if)
08-01 08:30:56.100 122 122 I r_submix: adev_init_check()
08-01 08:30:56.100 122 122 I AudioFlinger: loadHwModule() Loaded r_submix audio interface from Wifi Display audio HAL (audio) handle 6
08-01 08:30:56.100 122 122 I AudioPolicyService: Loaded audio policy from LEGACY Audio Policy HAL (audio_policy)
08-01 08:30:56.190 289 331 W zipro : Unable to open zip '/data/local/bootanimation.zip': No such file or directory
08-01 08:30:56.520 119 119 W GraphicBufferAllocator: alloc(2048, 1536, 1, 00001e02, ...) failed -12 (Out of memory)
08-01 08:30:56.520 119 119 E : GraphicBufferAlloc::createGraphicBuffer(w=2048, h=1536) failed (Out of memory), handle=0x0
08-01 08:30:56.520 119 119 E BufferQueue: [FramebufferSurface] dequeueBuffer: SurfaceComposer::createGraphicBuffer failed
08-01 08:30:56.520 119 119 E [EGL-ERROR]: void __egl_platform_dequeue_buffer(egl_surface*):1695: failed to dequeue buffer from native window 0x404906b0; err = -12, buf = 0x0,max_allowed_dequeued_buffers 3
08-01 08:30:56.540 120 120 W linker : /system/bin/app_process has text relocations. This is wasting memory and is a security risk. Please fix.
08-01 08:30:57.300 120 120 W linker : /system/bin/app_process has text relocations. This is wasting memory and is a security risk. Please fix.
08-01 08:31:00.860 120 120 I Xposed : -----------------
08-01 08:31:00.860 120 120 I Xposed : Added Xposed (/data/data/de.robv.android.xposed.installer/bin/XposedBridge.jar) to CLASSPATH.
08-01 08:31:00.860 120 120 I AndroidRuntime: JNI options: '-Xjniopts:warnonly'
08-01 08:31:01.960 120 120 I Xposed : Found Xposed class 'de/robv/android/xposed/XposedBridge', now initializing
08-01 08:31:02.680 120 120 E memtrack: Couldn't load memtrack module (No such file or directory)
08-01 08:31:02.680 120 120 E android.os.Debug: failed to load memtrack module: -2
08-01 08:31:03.070 120 120 I Xposed : -----------------
08-01 08:31:03.070 120 120 I Xposed : 01/ago/2014 06:31:03 UTC
08-01 08:31:03.070 120 120 I Xposed : Loading Xposed v54 (for Zygote)...
-snip-
Originally posted by Nightflier View PostI've done a reboot with ART "enabled". Here is the first part of logcat... near the bottom you may notice the line:
Then changing to art worked. I've got to reflash the rom with a 6gb system partition to gain more space for apps, but at least it is working now.
Our FTP server is down. We are working on it.Randy
There are currently 2794 users online. 1 members and 2793 guests.
