Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by GZD View Postif you appreciate my efforts this is the link for any donation:
This is the most stable ROM I tried, (thanks Randy!),
BUT, sometimes the tablet stops responding, it needs to reboot. Then boot time lasts a long time and when it boots, desktop is black, top right menu (slide down) does not exist anymore, bottom menu does not come up (need to use the hardware back button).
Only thing to do: flash it again, titanium backup again, lose an hour again...
Anyone has an idea?
Re: Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by mounoi View PostThis is the most stable ROM I tried, (thanks Randy!),
Anyone has an idea?
Sent from my Galaxy Nexus using Tapatalk
Hi experts,
I have a problem with the RR1.8 boot process.
I had a fully working RR1.8 on my M6pro tablet but I tried to change kernel with a Giouncino's one. Unfortunatly looks that no one worked for my tablet, just the RR original one.
The problem is now that even switching back to the RR original kernel doesnt work anymore: it loops in the bootanimation process...even after 15mins waiting...
I have already re-downloaded, erased IDB and flashed everything again but looks that I cannot boot in the system anymore...
do you have any suggestion?
Thank you guys,
Goll.
Caught in boot loop
Randy/Giouncino/anyone, I recently started experiencing a boot loop on my M6Pro. Several weeks ago I flashed RR KitKat 1.8 ROM and installed Giouncino's cpu1704h_VERY_LOW kernel. It has run rock solid until today. Now it hangs on Riley's boot animation screen. How do i proceed at this point to get the tablet to boot? Also, what could be causing this behavior? Thanks, JimLast edited by jdv007; 31 May 2014, 04:10.
Originally posted by jdv007 View PostRandy/Giouncino/anyone, I recently started experiencing a boot loop on my M6Pro. Several weeks ago I flashed RR KitKat 1.8 ROM and installed Giouncino's cpu1704h_VERY_LOW kernel. It has run rock solid until today. Now it hangs on Riley's boot animation screen. How do i proceed at this point to get the tablet to boot? Also, what could be causing this behavior? Thanks, Jimif you appreciate my efforts this is the link for any donation:
Ciao Giouncino, solved!as I told you in the Italian forum: I discovered that the boot looping was due to the wrong recovery used for first installation. I was trying to install the RR1.8 with the new TWRP as first recovery. This was the reason of the boot loop.
Switching back to the "original" recovery used in the RR1.8 and re-flashing everything I solved. Anyhow, the new TWRP works only after first system flash.
Inviato dal mio MI 2 con Tapatalk now Free
Originally posted by jdv007 View PostI used RR1.8. Could be an app. How do I uninstall it if I can't boot the tablet?if you appreciate my efforts this is the link for any donation:
Originally posted by jdv007 View PostAre you saying the only way to fix this is to re-flash the ROM?if you appreciate my efforts this is the link for any donation:
Originally posted by jdv007 View PostI re-flashed RR 1.8 with stock kernal and restored my apps and settings with Titanium Pro. Back in business. Thinking about another kernel to speed up CPU. What's appears to be the best one available gioucino?if you appreciate my efforts this is the link for any donation:
How to Unroot RR1.8 KitKat??
Hi all,
I've flashed RR 1.8 Kitkat. This system is smooth and more stable than JB. I just wonder how can I unroot this ROM. I want to install AirWatch to connect my company push e-mail but this AirWatch app need unroot system. I've tried on RootCloak without no luck even AirWatch is on the RootCloak compatible list.
Please advise.
Thanks....
There are currently 2802 users online. 0 members and 2802 guests.
