Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by giouncino View Post. Thanks.
Originally posted by jojjo View PostHmmm....i´m not so experienced in flashing tablets so I don´t know if I dare....I don´t want to risk anything. In your post there was many files. How do I know which one fits best? Is it safe to install a new kernel? I may wait until you guys that have more experience of this have tried. Well, maybe I dare...someday....but not today. Thanks.
Originally posted by abdul_pt View Post
Thanks for sticking with it Abdul
Re: Pipo M6 Pro RileyROM 1.8 KitKat
Thanks Abdul!
Sent from my M6Pro using Tapatalk
Mine still won't mount external SD...but I think my card is formatted NTFS...I will have to check.
Is there any way of doing a 1536x2048 resolution? This one is OK for the larger screen, but I have another tablet (iFive Mini3 Retina) that could use the larger screen size.Last edited by rrileypm; 06 May 2014, 17:58.Randy
Originally posted by rrileypm View PostMine still won't mount external SD...but I think my card is formatted NTFS...I will have to check.
Is there any way of doing a 2048x1536 resolution? This one is OK for the larger screen, but I have another tablet (iFive Mini3 Retina) that could use the larger screen size.
do i rename TWRP M6Pro.img to recovery.img and flash as normal ?
You can flash the file as is...by clicking the little box to the right of recovery.img in the flash tool....and browse to where you saved the file.
You can also rename the stock recovery file...rename this one as recovery.img and copy it to the RileyROM folder and flash. Just uncheck all of the other files from the flash tool.Randy
Tapatalked
beginner
Hi!
I wont be so popular with my questions. You have to belive me a I tried to find the solutions for my questions in the thread but I didnt!
I just bought my Pipo M6 Pro 3G tablet with Rockchip RK3188 processor with Kernel: 3.0.36+ (root@alex-System-Product-Name)#213, android 4.2.2.
I would like to try out the kitkat rom because this one is too slow/loggy for me. Do you think it worth it to try this one out? I would like to, but actually I dont really know how to do it?
How can I get to recovery mode?
There are currently 3034 users online. 0 members and 3034 guests.
