The ROM zip file has a First Time Users Guide that has all of the instructions.
Pipo M6 Pro RileyROM 1.8 KitKat
If you want to flash 1.8 I think you will see an improvement.
The ROM zip file has a First Time Users Guide that has all of the instructions.Randy
still battery draind too fast on KK
Dears, what did I did:
1.Battery saver installed
2. Greenify installed
3. Flight mode applied
Probably the only one what left is to try one of optimized Kernels...
If this works - which is confirmed as the best in energy saving now?Last edited by valerima; 09 May 2014, 09:18.
Greenify could help
Use ART framework and switch to a low power consumption kernel will be the best combination to increase battery duration!if you appreciate my efforts this is the link for any donation:
battery
Originally posted by giouncino View PostBattery saver is totally useless.
Greenify could help
i found someting when read about Xposed 2.4(?) is it the right direction ?
could you point to most popular kernel also...please...
Originally posted by valerima View PostDear Giouncino, sorry my medical brain cannot catch full scope information about art framework-
about the kernels: it depends on how lucky is your CPU.
take a look hare and make some tests with your tablet:
post #711if you appreciate my efforts this is the link for any donation:
Hi guys,
at first: sorry for my English
secondly: thanks, thanks and thanks.
When my M6Pro arrived, everything looked fine.
But when I tried to 2G connection, there was a problem. The display began to twitch, and the tablet was unusable. On 3G everything was ok.
After installing RileyROM 1.8 KitKat tablet ran even better, but 2G problem persisted.
Then I flash ROM with kernel_GPS_1.3_cpu_stock_gpu600_ddr648 and problems disappeared.
Now tablet runs absolutely great.
A big thanks to all who contributed to the solution.
Small thanks I also sent to PAYPAL
thanks
Honzik79
Czech Republic
thanks
Honzik79
Czech Republic
I suggest you to try!if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostYou can try a faster kernel, to achieve even better performace! You are using one of the most similar to stock. With other mod kernels you can also increase battery duration.
Only this one I was able to download.
I wanted to try a faster one.
Is there any diferent link to download them?
Originally posted by Honzik79 View PostI know, but I can not download them. When I try, all archives have only 27 kilobytes :-(
post #711
I suggest you to try againif you appreciate my efforts this is the link for any donation:
I tried kernel_GPS_1.3_cpu1704h_1325mV_gpu600_ddr744 and works really good.
THX
Hi i'm new here....
been having the tablet since a couple of months...
NOW IT WORKS !!!!
just modified as honzik79 says,
kernelkernel_GPS_1.3_cpu1704h_1325mV_gpu600_ddr744
and RR1.8 kitkat,now it works just like a top of the notch tablets...
unfortunately, i don't get a trustworth 3g signal, independently from where I am.
I tried at home, which used to show an "H", now it's just "E", very slow and very nerving...
I miss just only the old working 3g network....
do you mind the original libril library could do the job ?
thank you
NOW IT WORKS !!!!
thank you
So far I haven't seen any working 3G with any of the kernels I have used. Sometimes, in best connection areas, it gives dl speed up to 6mbits, but mostly drops to 2G or doesn't even find network.
Have to give stock kernel+libril a go with this...
There are currently 2111 users online. 2 members and 2109 guests.
