Pipo M6 Pro RileyROM 1.8 KitKat
I'm using the stock kernel.Randy
Originally posted by jdv007 View PostRandy and Giouncino, what kernel are you using with 1.8 KK ROM?
take a look here http://www.freaktab.com/showthread.p...-models/page34
on post #663if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View Post1.7/600/744 very_low Totally stable for me.
on post #663
Which runtime you are using? Dalivk or ART?I have tried using ART instead of Dalvik and tablet was crashing intermittently
with very_low kernel. Though the stock kernel works fine! Any idea if these runtimes are dependent on kernel?
Regards,
RedHatPerl
I've been using ART for a long time now and not had problems with any of the kernels I've tried. Maybe if you're having crashes try one of the not so low voltage kernel options or it could be if you've switched back and forth between Dalvik and ART it takes time for all the app caches to be cleared and settle down.
Sent from Tapatalk on my m6pro running Riley ROM 1.8 KK
Originally posted by Billcnz View PostI've been using ART for a long time now and not had problems with any of the kernels I've tried. Maybe if you're having crashes try one of the not so low voltage kernel options or it could be if you've switched back and forth between Dalvik and ART it takes time for all the app caches to be cleared and settle down.
Originally posted by ksaro1 View PostI too have ART enabled. I have gone back to the RR 1.8 KK. All mods that I tried crashed at some point when I had any browser open. This included Dolphin and Chrome. Now back to the original RR my M6Pro has been stable again. GPS is not working, as explained, but that isn't an issue for me. My experience is that all crashes for me are related to a browser being open.
They are stable with browsers!if you appreciate my efforts this is the link for any donation:
Originally posted by pikapika View PostHi all, is there any rule to install a custom kernel before or after than applying rom? I mean can we change the kernel after romming?
And no data loss.
If you experience instability you can try a "less modded" kenel, as I've explained here:
Regards,
RedHatPerl
Try a less modded kernel, your CPU is not so "pure" to grant stability with so low voltages...if you appreciate my efforts this is the link for any donation:
I am really impressed what you and rrileypm is doing here, thanks guys hope i can help sometimes.
Re: Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by Pipo2000 View PostHow about that :
[ATTACH]6304[/ATTACH][ATTACH]6305[/ATTACH]
21147 antutu score
Wooohooo
Verstuurd vanaf mijn M6Pro met Tapatalkif you appreciate my efforts this is the link for any donation:
There are currently 1954 users online. 0 members and 1954 guests.
