Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by Purpleyez View Post
Originally posted by wcraffonara View PostCiao giouncino,
I hope you can compile a kernel with a working 3G module! That would be great!!!!
take a look here:
post #602
all kernels have the 3G working module, EXCEPT the ones with RAM set to 720Mhz.if you appreciate my efforts this is the link for any donation:
Yeah! It works! Great!
Now, I've another problem (I had the same problem with RileyROM 1.6): I have phantom touches when I use the 3G module! This makes my tablet unusable!!! If I remove the SIM card then the tablet works perfectly!
How can I change the sensitivity of the touch display? I hope I can solve this by decrease the touch sensitivity.
Thank you!
Originally posted by giouncino View PostI do not use chrome at all on my tablet, I've found much more smoother the stock browser (that should have a chrome engine though) wrt chrome itself.
If you have any issue with a kernel, it is only necessary to flash another kernel over that one, no need to reflash the entire ROM!
Probably these new kernels generated from new source files should have some issue with chrome browser...
Tomorrow I will install it and check.
In the meantime I can generate new versions from old sources (from stock 1.8 kernels) to have 3G working and mod kernels only for frequency and voltages!
Old claro was extemely stable, 0 crashes in last couple months.
Thank you!
Probably there is a shortcircuit on 3G antenna. You can try to open the tablet and re-soldering it again.if you appreciate my efforts this is the link for any donation:
Originally posted by fokemon View PostI just cant get this... All new kernels are crashing, with dolphin and chrome. It takes 10-120mins between shutdowns. But they occur, with all kernels i've tried.
But, I have now tried few several kernels, only that gets any connection here is old claro 720. That also gives better fix for gps than these new ones. It took 10mins to get 120ft accuracy, when old claro+stock libril does it in 2! I am using 1325/648 at the moment, and this seems to be only stable one for me now.
I also suffer with navionics hd app, but it has done that before. Actually, same issue when i installed KK for the first time. Annoying is, that I should be using it next week...
Originally posted by fokemon View PostAbout this... First of all, mobile network at my home is s..t. Thus, testing 3g here is bit difficult.
New kernels have better GPS and better 3G (except 720Mhz for RAM). For you is not true... Are you sure of the kernel you are using?
I'm a bit confused...if you appreciate my efforts this is the link for any donation:
thankyou
running the latest -
kernel_GPS_cpu1704h_VERY_LOW_gpu600_ddr768.zip
so far running flawlessly.....awesome stuff....magnifico
All these I have tried:
kernel_GPS_cpu_stock_gpu600_ddr648_NEW.zip
kernel_GPS_cpu1704h_1325mV_gpu600_ddr768.zip
kernel_GPS_cpu1704h_VERY_LOW_gpu600_ddr648.zip
kernel_GPS_cpu1704h_VERY_LOW_gpu600_ddr672.zip
kernel_GPS_cpu1704h_1325mV_gpu600_ddr720.zip
kernel_GPS_cpu1704h_1325mV_gpu600_ddr672.zip
kernel_GPS_cpu1704h_825_users_gpu600_ddr648.zip
kernel_GPS_cpu1704h_1325mV_gpu600_ddr648.zip
All of them chrash within few minutes of usage. Most of them give less 3G than my setup now. Most of them have slower fix in GPS than my setup now.
So, I am back to
kernel_kitkat_1.8_cpu1704h_1325mV_gpu600h STOCK_ddr720_Claro
+ stock libril to enable 3G. No chrashes at all...
So, I am back to
+ stock libril to enable 3G. No chrashes at all...if you appreciate my efforts this is the link for any donation:
There are currently 4227 users online. 1 members and 4226 guests.
