Pipo M6 Pro RileyROM 1.8 KitKat
I just tried to simplify #3Randy
Originally posted by thorpe1968 View PostOdd I havent noticed any problems with this latest rom, in fact works better than the Jelly bean one, faster and no lagging. Also everything is compatible in the market!
Ray
Applications
-Drivea
-iOnRoadLite
-QR & Barcode Reader
-IP Webcam
-HDR Camera
There is problem with camera interface with kitkat, but no problem with Jelly Bean.
Originally posted by hikka View PostHave you tested applications using camera ?
Applications
-Drivea
-iOnRoadLite
-IP Webcam
-HDR Camera
Yes I have not had any problems with camera or the camera software. I am running on a Pipo Max M6 PRO 32gb model with riley rom kitkat 1.8 and no modified kernels: using stock kernel that comes with riley rom.
Ray..
Originally posted by thorpe1968 View PostYes I have not had any problems with camera or the camera software. I am running on a Pipo Max M6 PRO 32gb model with riley rom kitkat 1.8 and no modified kernels: using stock kernel that comes with riley rom.
Ray..
I didn't find settings to repair the problem. It is mysterious, if others don't have this kind problems.
Just for information: modified kernels DO NOT affect in any way camera functionalities!if you appreciate my efforts this is the link for any donation:
Originally posted by Billcnz View PostYes, the stock camera works fine but there's an incompatibility with third party camera apps. Either the view finder does not update properly or the app force closes.
Re: Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by smokva View PostFirst of all thanks for this great rom. My m6 pro was slow and sluggish with jelly bean roms. Now it works fast....great!
But i have noticed that camera isnt working on 1.8 rom. To be honest it didnt work on 1.6 rom on my tablet toi.
Sent from my M6Pro using Tapatalk
Sent from Tapatalk on my m6pro running RR 1.8 KK, kernel low V2
Originally posted by rrileypm View PostI agree with you that Pipo had a very stable last Jellybean release...and many people have stuck with my 1.6.1 ROM without any problems.
All of Pipo's KitKat firmware is still classified as beta, with a list of known issues. When I sit down to make a ROM, I usually have know earthly idea whether the major things are fixed or not.
Originally posted by Billcnz View PostCamera should work, apart from the issues mentioned above, otherwise you may have a hardware issue.
Everything was working fine with original pipo jelly bean ROM. Than I installed Riley ROM 1.6.1 and it suddenly didn't work. Now I installed 1.8 ROM and it doesn't work again.
I don't use cam on tablet so its not a biggie, but the flash is not working too and I would like to have it as a torch.
I need someone to test a new TWRP. I'm trying to solve the screen issue, i implemented this patch on another RK31 tablet and it worked quite well.
This image could let you stuck on recovery without the possibility to choose anything, so considered yourself warned.
If that happens just flash a misc.img.
To the tester's i need the recovery.log, and feedback.
Thanks.
TWRP M6Pro
Abdul, I can test it. Stay tuned.Randy
There are currently 2192 users online. 2 members and 2190 guests.
