with a wrong bootloader, the tablet doen't boot at all. (nothing on the screen)
Pipo M6 Pro RileyROM 1.8 KitKat
[QUOTE=spawnofdonny;155941]Originally posted by jc0v View Post
with a wrong bootloader, the tablet doen't boot at all. (nothing on the screen)if you appreciate my efforts this is the link for any donation:
[QUOTE=giouncino;155946]Originally posted by spawnofdonny View Post
NO!
[QUOTE=spawnofdonny;155948]Originally posted by giouncino View PostI mean if it was using the jelly bean bootloaderif you appreciate my efforts this is the link for any donation:
Originally posted by godsbrain View PostI updated yesterday to 1.8 but I can't Play any games. It looks like the fullscreen mode is bugged. Do You have any Solution? Should I flash it again?
thanks!
I tested the Game "Hay Day". It began to load and then a there is a popup "scroll down for fullscreen" and then it looks like the game is in "pause mode". Other games have the same problem...
The jellybean rom worked fine, was only a bit laggy but there weren't any issues like now. What can I do???
Re: Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by godsbrain View PostI tried to flash it again and same problems
Sent from Tapatalk on my m6pro running RR 1.8 KK, kernel low V2
Originally posted by Billcnz View PostProbably this game and some others you tried are not fully KitKat compatible. There will be other games that work but if you want these ones you may have to go back to jb.
Sent from Tapatalk on my m6pro running RR 1.8 KK, kernel low V2So this is an issue of the game, right? I thought that there will be maybe a fix for this. Thats stupid.
Thanks!
Originally posted by asimilator View PostHi ...
I'm currently on riley's 1.6 and trying to flash my pipo with KK 1.8 but (after erasing NAND) when i try to flash rom i get "Test device failed" error...
Any hints?
Thank You!!!
this is a problem for not good usb connectionif you appreciate my efforts this is the link for any donation:
tnx a lot for a hint, but it seems that retrying doesn't help... i already tried hundred times (also changed usb cable) but no luck...
tried to flash it with 1.6 again and it passed without any problem...
Originally posted by asimilator View Posttnx a lot for a hint, but it seems that retrying doesn't help... i already tried hundred times (also changed usb cable) but no luck...
well... now i'm really depressed... although flashing it with 1.6 in finless tool passed without any errors, my pipo turned on with dead android logo and i'm not able to start it in flash mode any more...
any tip would be priceless...
Originally posted by asimilator View Postwell... now i'm really depressed... although flashing it with 1.6 in finless tool passed without any errors, my pipo turned on with dead android logo and i'm not able to start it in flash mode any more...
All of the precautions against bricking are clearly documented in post #1...including links to the threads explaining how to unbrick your tablet.Randy
Originally posted by Billcnz View PostYou need to tick the bootloader when going back to jb from kk
... I'm really not sure what went wrong but what are my options now..
How can i start flash mode now.. I tried esc+reset+power but nothing happens.. Only dead android logo appears.
Sent from my GT-I9195 using Tapatalk 2
There are currently 1806 users online. 2 members and 1804 guests.
