Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by X-Ray View PostYou can use Nova Launcher to delelte google search bar.
Like X-Ray said : the you can DELETE that anoying search bar and...the UI gets even a bit faster...
Giouncino : I'm also running ur Very low kernel on RR1.8 and have absolutly no problems what so ever...
Now I did'nt have any problems with your previous very low voltage kernels either (from 1.4 and up) so I didn't expect to see any troubles now... what I did notice however is the ENORMOUS extend of battery life now.
I can do easly 7 hours of normal use and stil have +/- 30% batt left.
So :I bow for the great battery saver man !
Thankx !!!
On a side note : This RR1.8 based on KK enables me FINALLY to re-use a local newspaper app HLN (Het Laatste Nieuws). This app wouldnt work on M6Pro from the beginning, nor with stock, nor with RR. Always 1/3 of the screen frooze, 2/3 scrollable...
Now with RR1.8 (KitKat) everything is normal... YIEHA
Originally posted by Pipo2000 View PostNova Launcher is for me the best launcher ever...
Thankx !!!
With the low_voltage_v2 I think I've found the best way to save power maintainig stability, for me and for many of you this is totally stable too!if you appreciate my efforts this is the link for any donation:
Glad to hear you got it worked out, with low voltage.
Gioucino,
Do you still need that stock libril file?Randy
Widget and GPS
Few hours ago I've flashed my Pipo M6 Pro with this rom, everything seems to work properly, but in settings there's nothing about gps, it doesn't exist. Another thing that I'm unable to find is the screen for widgets, after tapping on drawer I find only two pages for apps and no one for widgets.
We must wait for an implementation of this rom?
For GPS, in settings go to Location and under Mode select Device only and turn Location switch on at the top right of the screen.
As far as the Widgets go...I see them on my app drawer. I'm using Apex Launcher, though.Randy
great rom shame i cant run v2 kernel or any other posted?
Made my own and get 193000 so happy now
now this boot loader animated image is he on drugs can i get some
i liked the 1.6 boot image it just needed to be full screen and it would of been awsome
BTW if any one wants my unlucky cpu kernel ill post it in the correct thed for ya
cheers guys great work keep it up
Thankx !!!
Originally posted by rrileypm View PostFor GPS, in settings go to Location and under Mode select Device only and turn Location switch on at the top right of the screen.
Mounted nova launcher and... voilĂ all widgets have appeared.
The rom is very fast and for the moment I've not had any other issue.
Thank you very much for your work.
Originally posted by Almar View PostTurned on location switch and started gps fix; fixing OK in almost one minute, much better than previous attempts with JB roms. It's however a pity that theres'nt a button to switch on and off gps.
Also the buttons for wi-fi/bt/gps/sync/brightness are present between the widgets.if you appreciate my efforts this is the link for any donation:
Originally posted by rrileypm View PostGlad to hear you got it worked out, with low voltage.
Gioucino,
At the moment stock kitkat for M6pro doesn't have deep sleep enabled.
I still need to check the one of m8HD that the user "manao" kindly sent me.
Randy if you have the libril coming from other kitkat releases I will test them for sure!if you appreciate my efforts this is the link for any donation:
I'm pretty sure I have all of the stock files from the current KitKat ROM's I've done.
Let me zip them all and I'll give you a link.Randy
Randy
There are currently 1653 users online. 0 members and 1653 guests.
