Pipo M6 Pro RileyROM 1.8 KitKat
You can use root genius run from a PC, it will give you back root access to the tabletif you appreciate my efforts this is the link for any donation:
Thank, I had managed to re root it by installing Kingo android root switching on usb debugging on the tablet and installing the ADB drivers then running the kingo programme and letting it do its stuff. Root done. Seems to also install a Chinese market on the tablet, but this can easily be removed.
This did not however after following previous instructions in post #76 prevent Sky Go from seeing the tablet as rooted.
Started a new thread on this issue so as not to detract from actual rom issues in this thread.
SkyGo Tablet seeing rooted issue
TWRP Loop
I have got trouble with TWRP. Today I flashed my pipo m6 with this rom and all goes well;
Then I try to reboot into recovery with the app, twrp was load but from there I can't reboot in Riley....
Inside twrp in Rebbot menu I try:
Reboot->System: no work, twrp was load again
Reboot->Power Off: pipo reboot into twrp
Reboot->Bootloader: pipo black screen
Reboot->recovery: reboot in twrp.
Someone can help me???
THANKS!!!!
See the thread in the stickies.
Flash the misc_system.img by itself (uncheck everything except misc.img) as the misc.img file. Don't erase idb.
Sent from my SAMSUNG-SGH-I537 using TapatalkRandy
Also...everyone needs to download and install the latest Petrus Reboot app from the App Developers Kitchen...that fixes the problem.
Originally posted by fokemon View PostSo, I tried few kernels, and none of them got Navionics HD working. So, I flashed JB back, and it worked fine. Now I flashed kitkat back, and with stock kernel it works again. Next move is to try new one...if you appreciate my efforts this is the link for any donation:
Re: Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by 9michael9 View PostBrowsing process (moving in a page) is king of Staterring/not smooth. This is strange, since the mchine supposed to have enough "Horse Power" to handle browsing without "hiccups". Any remedy?
Sent from Tapatalk on my m6pro running Riley ROM 1.8 KK
Worked!!! Thanks a lot!! Sorry if I haven't search enough around the form but... Panic!!
Thanks again!
Originally posted by fokemon View PostSeems smooth, and even I don't have lucky cpu to use low voltage one, I got 20400 with clario kernel. Next beers are on me, lads!
Don't worry Claro version of the kernel is good enough....if you appreciate my efforts this is the link for any donation:
There are currently 2087 users online. 1 members and 2086 guests.
