Inviato da me
Pipo M6 Pro RileyROM 1.8 KitKat
Poor 3G signal also here with KK
Originally posted by prezes551 View PostThanks fo exellent work. Rom works smooth and seems to be stable, but 3g signal is really poor, sometimes my pipo m6 pro looses it at all. On stock firmware I haven't this problem - the 3g signal in same conditions was full.
Prezes have You found a solution to increse signal strength?
Otherwise RR 1.8 with ART in use is running very nice and will see if low voltage kernel works for me
Janne
Perdón por mi ingles. Quiero instalar la Pipo M6 Pro RileyROM 1.8 KitKat desde CWM y son estos los pasos a seguir: 1) Copiar a la raiz system.img ;boot.img ;kernel.img y ROMInstall. 2) Reiniciar en recovery. 3) Wipes. 4) ejecutar ROMInstall. 5) Rezar para que todo salga bien
Pardon for my Englishman. I want to install the Pipo M6 Pro RileyROM 1.8 KitKat from CWM and the steps are these to continuing: 1) To copy to the root system.img; boot.img; kernel.img and ROMInstall. 2) To restart in recovery. 3) Wipes. 4) to execute ROMInstall. 5) To pray in order that everything goes out well
I got this too
Originally posted by zvezdopad View PostSorry for bad eng.
What need I do, if I have install wrong kernel and tablet does not run (stop on logo freektab)
TWRP is ok.
"Reset" , then "VOL+ , Power" dos'nt help.
Thank you.
Janne
Originally posted by Janne View PostI flashed Giuncinos very low v2 kernel and now the tablet wont boot. I only see rileyrom logo and after that screen goes black. No luck either trying to get it back into flash mode. Any suggestions? Anyone???
Janne
I don't even know what i did, popped sd- and sim-cards in and out and charged for a while, then it suddenly booted and connected to the flash tool as i pressed the power button.
I guess I most definetely have one of the unlucky CPU's
Janne
TWRP is ok.
Thank you.
1. Reset
2. Hold reset and VOL+ and POWER
3. Reset off
4. Profit
Poor 3g signal
Originally posted by Janne View PostI noticed this too, with RR 1.6 I got full bars of 3G and five minutes later (after flashing RR 1.8) only one bar. I presume the modem power has been decreased to save battery...? Any way to crank the power up myself, e.g. by editing build.prop or something? I'm kinda new with these things
Janne
Darek
Originally posted by Meettya View PostJanne, Prezes - I`am in this boat too
3G works only technically - its detected and show something, but practically useless at all
Do you try to flash original Pipo KitKat fw?
If someone know something about how it will be fixed - share it please.
The stock libril for Kitkat doesn't allow to go in deep sleep.
The Jelly bean libril file is compatible in KitKat but with decreased sensitivity.
The only way is to copy the kitkat native libril file.
I can attach the file on wednesday (because now I'm out of office where I have the original file).
Otherwise you can flash the stock ROM (that has a LOT FASTER BOOT TIME) then use "root genius" to have root access. In this way you will have faster boot and full 3G performance....if you appreciate my efforts this is the link for any donation:
TWRP is ok.
Thank you.
If necessary try to do the same with the wall charger connected to the tablet.
It's almost impossible to brick this tablet with a mod kernel, believe me.if you appreciate my efforts this is the link for any donation:
Originally posted by Meettya View PostOh, thanx in advance
"Unsleeped, but with 3G" or "sleep, but 3G unusable" - hard decisions, rly.
We need that theese chinese FINALLY wake up and make a new ROM with deep sleep activated by default (correct the libril file)...
until that we need to decide to have bad 3G but deep sleep or vice-versa...if you appreciate my efforts this is the link for any donation:
Re: Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by josedebenidorm View PostPerdón por mi ingles. Quiero instalar la Pipo M6 Pro RileyROM 1.8 KitKat desde CWM y son estos los pasos a seguir: 1) Copiar a la raiz system.img ;boot.img ;kernel.img y ROMInstall. 2) Reiniciar en recovery. 3) Wipes. 4) ejecutar ROMInstall. 5) Rezar para que todo salga bien
Sent from Tapatalk on my m6pro running Riley ROM 1.8 KK
That's correct.
CWM isn't KitKat compatible, for one thing.
Next, upgrading to KitKat involves necessary restructure of your NAND partitions to include a Metadata partition which hasn't existed in previous Android versions. YOU WILL BRICK YOUR TABLET IF YOU DON'T DO YOUR HOMEWORK. Read post #1 carefully, and look at the threads linked in that post.
Your ONLY option is to flash this ROM (CAREFULLY FOLLOWING ALL OF THE NECESSARY PRECAUTIONS) using the included flash tool from a Windows PC (NOT WINDOWS 8.1).Randy
Best kernel?
Hi, I flashed today KitKat and everything seems to work perfectly until now. Unluckily I couldn't use v2 kernel (I have not a lucky Cpu) and so i flashed Claro Kernel, but is it there something in the middle between the 2? I have not exactly clear the meaning of the other four kernels... With Claro I get a Antutu of 19777. Another problem is that ART gives me some problems with some apps; At present I reverted to Dalvik, but is it a way to make ART more stable or some other parameter to change? With ART, Lucky Patcher told me that in the Rom there is some problem, but it didn't specify which...
I know that I am posing many problems, but I relly LOVE this Rom and would like to bl able to get the maximum from my Pipo...Thank you in advance to who will be so nice to answer...
There are currently 1604 users online. 0 members and 1604 guests.
