Sent from Tapatalk on my m6pro running Riley ROM 1.8 KK
Pipo M6 Pro RileyROM 1.8 KitKat
R: Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by PaulHD View Postsupplement - everything except video works 100%, in any video can sometimes 10 minutes, sometimes 30 minutes of play before he freezes.
How can this be prevented?Originally posted by claro966 View PostIt happens to me too, it freezes after few minutes of video player.
I run on Claro kernel and I don't know if it's the same with the stock one, but maybe it's independent from the kernel.
Will see another player
Inviato dal mio M6Pro utilizzando Tapatalk
Re: Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by lejawin View PostHi guys.
I'm currently on RR 1.7 but I want to update my M6 pro to RR 1.8.
Can I use titanium backup? Or it's better to delete everything?
Thanks in advance!
Inviato dal mio M6 utilizzando Tapatalk
Sent from Tapatalk on my m6pro running RR 1.8 KK, kernel low V2
After flashing 1.8, I did a "restore missing apps with data" and everything works fine.Randy
Originally posted by Keule View PostHey there,
i just installed the new ROM to my M6pro 16GB WiFi and performancewise it works like a charm. Great work! Big THX! Unfortunately WiFi does not work (saying "Turning Wi-Fi on..." forever). I followed the instructions in the Manual supported with the file and used the 6GB parameter file. After installation booting up took quite a long time. After first boot I restarted the tablet. Second boot was much faster. But event though I did a reboot, the message "Turning on Wi-Fi..." was still active. Only turning on airplane mode, and rebooting afterwards could make it disappear. But when i tried to turn on wifi again, the same happened. Tried resetting, installed the ROM for a second time. Nothing worked. Any ideas what I could have done wrong or whats wrong with my installation?
A second weird thing happends, when I try to turn on Bluetooth. It turns off again by itself after maybe two seconds. But since i dont really need BT this is ok to me. Just mentioned it, just in case the two problems may have a common root.
Great Job!
I have just flashed my girlfriend's M6Pro 3G with this and I am more than pleased. She has been almost abandoned it, because of the laggy default ROM. Now she likes it very very much again. It works very very smooth, almost like an iPadJust one thing.. She was using it almost only for HayDay (farm game) which is the only thing that's not working with this ROM. It starts, but the screen is not updating. It has to be something with the resolution or the "floating" top and bottom button/status bars. Because the only time when you get some screen activity is when you swipe your finger to show/hide them. Is there a way to fix that? Thanks in advance! P.S. after some more testing - for sure the reason is stupid game code which does not survive resolution change due to top/bottom bars hide. If there's a way to make them permanent it would work. Is there such option?
Decided to give this one a try and so far I am very pleased.
Everything is working and working better than when I was using the "M6 Pro RileyROM 1.6.1".
In conjunction with Gio's "kernel_kitkat_1.8_cpu1704h_gpu600h STOCK_ddr720_VERY_LOW_V2" everything is sweet.
I actually have better battery life and a faster machine. Even the GPS seems to be better.'
Great work you guys. You two rock
Thank you very very much.
spinna
Originally posted by ace23 View PostI flashed the rom using the riley1.8 rom and now i'm missing the option to minimize the lower bar and use the whole screen is this option still available somehow? It was a button looking like an arrow pointing downif you appreciate my efforts this is the link for any donation:
There are currently 2081 users online. 1 members and 2080 guests.
