Sent from Tapatalk on my m6pro running Riley ROM 1.8 KK
Pipo M6 Pro RileyROM 1.8 KitKat
Re: Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by PaulHD View PostThis rom works great as long as I do not play video, then freeze or reboot it.
I tested the "different" kernels.
I use the stock kernel KK 1.8
Does anyone have this problem too?
What solution can I use?
Now I'm using low_voltage_V2 that is STILL totally stable for me.if you appreciate my efforts this is the link for any donation:
Yap, I have hard-luck tablets, but it ok
Only problem, that I have had with this kitkat release, is other applications using camera.
For example barcode reader , augmented camera applications, HDR camera ... are not able to use camera correctly.
Kitkat own camera application is perfect and gives better images than in Jelly Bean.
Is this common kitkat problem ?
I tried go back RR 1.6 Jelly Bean, was not able to reflash it.
- first erased the flash in RR 1.8 Rom Flash tool
- after that I was not able to start flashing with RR 1.6 with Loader ticked
(reset loop and tablet don't response , when trying to flash with RR1.6 settings)
- instead I had to reflash RR1.8 kitkat back
Originally posted by giouncino View Posthere is the stock libril file that needed to be EXTRACTED from the .zip and placed with a file explorer into: /system/lib/ folder overwriting the RileyROM libril file.
Pay attention that the system folder has to be enabled in R/RW mode (otherwise you will not be able to copy the file).
[ATTACH]5546[/ATTACH]
After that, reboot the tablet.
With this file: 3G will be better, but you will loose deep sleep functionality (I suggest you to backup original libril file somewhere else).
This file is compatible with all kitkat releases of RK3188 tablets (this file has been extracted from the M6pro stock kitkat release).
Originally posted by fokemon View PostI tried this, but got only error message from file explorer. System and lib files claim to be read/write. And i should replace with the same named file, I assume? There wasbfile named libril.so, too...if you appreciate my efforts this is the link for any donation:
Originally posted by fokemon View PostGetting bit better, now I reach 1,3-1,6Mb. It should be around 5-10 anyway...
For some reason it required few hours to wake up.
Thank you, Italian Wizard!
How can this be prevented?
Originally posted by PaulHD View Postsupplement - everything except video works 100%, in any video can sometimes 10 minutes, sometimes 30 minutes of play before he freezes.
How can this be prevented?if you appreciate my efforts this is the link for any donation:
There are currently 3317 users online. 0 members and 3317 guests.
