Pipo M6 Pro RileyROM 1.8 KitKat
Flashing the alternative misc.img only recovers from being stuck in recovery, and not booting to the system. If you are experiencing a kernel problem, it won't help to flash this misc.img.
Petrus has actually updated his reboot app, which I have tested and it works fine on the M6 Pro. I will begin adding it to my future ROM's.
In the meantime, here is the link to the new reboot app that you should install on your M6 Pro. No more getting stuck in a recovery loop when you reboot to recovery:
linkRandy
Do you have an external SD plugged in? Try adding one, if not. If you have one, try removing it. If that solves the problem, run a chkdsk from Windows and check for corruption.
Sent from my SAMSUNG-SGH-I537 using TapatalkRandy
Thanks for the reply, it turned out that my titanium backup had installed some apps to the SD card by accident. They weren't on SD when I did the backup before flashing this morning. But Its all sorted now. Thanks again. I will pop a donation once I get my first pay cheque. Finally got a job after being made redundant 4 years ago.
Re: Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by anavrin View PostGot 1.8 rom with VERY_LOW_2 kernel. Untutu score 20800, runs perfectly! Thank you, guys!
Only problem is freezing music on native music player.
Peace from Kiev!
Sent from my m6pro running Riley ROM 1.8 KK
Originally posted by Billcnz View PostYou shouldn't have that problem with music player, try one of the other kernel options
Besides there are no any problems with ROM, works smoothly.
Originally posted by anavrin View PostI dont think that problem with kernel. Custom music players (Poweramp, Jet) runs with any problems. Checking on hard .flac tracks.
Originally posted by VanJ View PostWhat FS (RW,RO) does this ROM support on external SD card?
There are currently 2092 users online. 1 members and 2091 guests.
