Pipo M6 Pro RileyROM 1.8 KitKat
    Aaah ok thanks for your reply there.
    Yes im glad its not a ROM issue then thats good to know.
    Ill try my google account from another phone then and see if that fixes it here.
    Otherwise ill just wait. I did try clearing the cache also. Followed this site 3 times:
    Google Play Error 403 Solutions: App could not be downloaded due to an error 403 when try to update or re-install that app from the Play Store.
    No luck!
    I'll keep you updated as to how i go anyway
      Originally posted by gooner1511 View Post
      Tried my phone with my usual account to see if that was affected and it worked when i tried to download something from play store (no 403 error),so i went back to the tablet tried again with the same account and it worked no errors and all seems to be working again.
      sorry this isnt a difinitive answer but this what worked for me,
      Fixed thanks to that ^^
      many thanks!
        I have flashed the fw but it is not stable for my table
        also as previous fw of kitkat 1.7
        I am facing only reboots and reboots
        as i opened any app or go to menu it goes reboot
        anyone knows why i am facing this type of situation
          Did you erase nand before you flashed fw
            yes i have erased the NAND IDB
            I have followed all the steps written on user guide
            given in zip file of fw
            I also observed when I turn on wifi then the
            tab freezes or reboots otherwise remains normal
              screen resolucion
              Thank you Giouncino! I thought I was losing my mind..
              The tablet is running great, I wonder how much more the tablet can be pushed since it is running so smooth on the lowest kernel you have. Also, I used the tablet for watching a movie, 2 hrs, read and surfed for another two hours, and left it on in sleep for 7 hrs, still at 75% battery....
              BR
              Originally posted by giouncino View Post
              the res is still 2048x1536, the presence of the bottom bar make antutu to recognize a little bit wrong value!
              Great result for your tablet on antutu!
              With the very low kernel you will notice the battery lasts a little bit more too.
                Re: Pipo M6 Pro RileyROM 1.8 KitKat
                BR
                Which kernel is this you are using?
                I'm running claro which is smooth giving me 21090 in antutu.
                Which is amazing for this tablet, thank you to Randy and Giouncino you're efforts are really appreciated
                Sent from my GT-I9100 using Tapatalk 2
                  kernel
                  Hello,
                  I'm running the low voltage v2 kernel..
                  Which is amazing for this tablet thank you to randy and giouncino you're efforts are really appreciated
                    Originally posted by 9michael9 View Post
                    Thank you very much
                    Any reason why it is not included in the ROM's zip?
                    It's there...look in the RileyROM folder. I explained all of that in post #1.
                    Sent from my SAMSUNG-SGH-I537 using Tapatalk
                    Randy
                      Hello,
                      That is the BEST kernel (lowest voltages, highest freq) but you need to have a lucky CPU as seems you have.
                        Thx for the ROM rriley!
                        After installed and restored apps I did a benchmark with antutu under Dalvik.. run it 4 times and got 20200-20300 every time with modified kernel.
                        Switched to ART and after at long "android is upgrading" and did four runs in antutu.. got between 20810-20885!! Nice!
                        Antutu is just numbers and I haven't played around with it yet to see if it feels any snappied than 1.7.
                          Hello,
                          Thanks will give it a go.
                          lower voltage=less battery drain is that right?
                            you needed only the misc.img file.
                            You can find it in the specific thread.
                            I am sorry to bother again, but the misc.img file is not available at the link provided. Is it different from the misc.img file provided with the ROM? Comlete reflash of the ROM didnt fix the problem.
                              here it is:
                                Yes it is, but you need a lucky CPU to increase frequency reducing voltages! otherwise you have onli freeze/bootloops!
                                How to see if you have a lucky CPU? try the various kernels and see what happens...
