Pipo M6 Pro RileyROM 1.8 KitKat
I'm curious...what troubles are you having with the reboot app?Randy
If you are flashing v1.8.2, the reboot app has been updated, and you won't get stuck in recovery mode.Randy
good to know, I do not have the m6pro to test itif you appreciate my efforts this is the link for any donation:
good to know, I don't have the m6pro any more to test itif you appreciate my efforts this is the link for any donation:
Originally posted by r0llingmuffin View Postmy pipo m6pro doesn't boot up ... it's stuck to the pipo m6pro rileyrom screen ... please hlep .... :-)if you appreciate my efforts this is the link for any donation:
Sounds like a corrupt data partition. Use pin hole reset to shut off, then you could boot to recovery by holding down volume+ and power buttons and if you had made a backup in TWRP you could restore the data partition and get running quickly otherwise you may need to reflash
Sent from Tapatalk on my m6pro running Riley ROM 1.8 KK
HDMI & Miracast
My friend owns an m6Pro and has installed 1.8 Rom. He is very pleased with it. Everything works perfect except HDMI and Miracast. HDMI is not working at all. With Miracast you can see the dongle but when you try to connect the tablet restarts. Do you have the same symptoms? Is there a workaround or is it a ROM problem?
Originally posted by porthos View PostI have had same issues - return to JB 4.2 solved my problems with Miracast and others.
with ROM 1.8 HDMI is working properly,
miracast is not working on any Kitkat rom for m6pro.
It will not be fixed, development with m6pro is ended.if you appreciate my efforts this is the link for any donation:
The last ROM for M8HD has miracast working.
I see that some files are missing in old ROM where Miracast is not working
These files are :
libgcastv2_base.so
libgcastv2_support.so
libjgcastservice.so
You can try if you add them to /system/lib with rw-r--r-- permissions
here are the files we have on M8HD :
miracastlib.zip
Miracast not working
Originally posted by stevejc View PostThe last ROM for M8HD has miracast working.
These files are :
libgcastv2_base.so
libjgcastservice.so
[ATTACH]8346[/ATTACH]
I installed them on my Pipo Pro M6 with RR1.8.2, but the same thing:
Just after making the connection with our LG, the pipo still reboots....
There are currently 1250 users online. 0 members and 1250 guests.
