Pipo M6 Pro RileyROM 1.8 KitKat
Απ: Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by rrileypm View PostYou can try backing up the userdata partition and try to save it to the external SD...if TWRP will mount to external SD.
A brand new ROM will be released tomorrow sometime. I've just put the finishing touches and the whole Pipo Project Team needs to approve it before we release it. Stay Tuned.
Originally posted by panava View PostW8ing….
Un saludo,
Satbeginner
OOPS, sorry I forgot to post it in this thread.
Thanks!!!!Randy
That's correct...it's only for the M6 Pro.Randy
Display Setting
Now I have the Riley Rom 4.2.2 and there is no possibility to change display setting from RETINA to less detailed, in this new 1.8 Kit Kat is it present?
I got feeling and information that low resolution will speed up the tablet, but with my current ROM I cannot do that.
Thank you
BR
Enrico
Screen HD and lower resolution in New v1.0 ROM
Originally posted by enricogreco View PostNow I have the Riley Rom 4.2.2 and there is no possibility to change display setting from RETINA to less detailed, in this new 1.8 Kit Kat is it present?
Thank you
BR
Enrico
But, in my humble opinion, the visual screen quality goes down significantly (at least on my M6Pro), so I am not using the low res.
The new ROM has an average AnTuTu score of 24500, so why bother going down in resolution.
You can read all the info on the new ROM here:
Un saludo,
Satbeginner
Thank you very much for your fast reply.
I have some delay on my deivce and some "block" of the system quite often and reading on the net the low resolution will improve this problem, unfortunately I cannot try it now, so if the new ROM is ok and fast on high resolution, good, otherwise I would like to try the low resolution.
Ciao
Occasional freezes on RR1.8.2
Originally posted by enricogreco View PostThank you very much for your fast reply.
Ciao
me too had occasional freezes using RR1.8.2,-or any other earlier ROM- when using both the stock browser as well as Chrome or Firefox when browsing through pages with a lot of graphic information on it.
I know my tablet has a very unlucky CPU, I can not use any overclocking or memoryspeed adjustments what so ever.
Using the stock Pipo-ROM was the most stable, but 4.2.2 only.
I am using the new v1.0 ROM for several days now, and I had no problems so far! (fingers crossed)
Un saludo,
Satbeginner
At least for some...I believe we've found the Holy Grail for this tablet, at least. Except for a few unlucky reports...the new Pipo Project ROM is the best yet.Randy
Re: Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by rrileypm View PostAt least for some...I believe we've found the Holy Grail for this tablet, at least. Except for a few unlucky reports...the new Pipo Project ROM is the best yet.
I'm still hoping we can get a fix or update to the Chromium Web view problem I outlined in an earlier post. Maybe the version used in cm11 could be ported over. That's really the only bug left that irritates me.
Sent from my SM-T520 using Tapatalk
I agree.
Do me a favor, though...and post those suggestions over on the [Pipo-Project] M6 Pro thread because that's where Maakie/D33 look for feedback. I'm not sure they check the old RileyROM threads much. I think Maakie is working on a few things he's found.Randy
Sent from my M6Pro using Tapatalk
There are currently 1928 users online. 1 members and 1927 guests.
