Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by stevejc View Postso, it must have something else more missing.
1. Press the reset button on the back with a paper clip.
2. Launch the Flash Tool on your PC with the tablet connected.
3. Hold the ESC button and press Power...your tablet will boot into flash mode.
4. Erase IDB.
5. Try flashing with a different parameter file selected and see if it boots.Randy
The notification area in the bottom of the flash tool will say "Found One Device in Loader Mode".Randy
Try the 10gb parameter file and see if that works. Just click the little box to the right on the parameter line...browse the RileyROM folder for parameter10.Randy
Great...thanks for the update.
Glad you got it going.Randy
This ROM has all of the features noted in Post #1. Yes, it's rooted.Randy
Mounting cifs crashes the tablet
I am trying to mount a windows share by using either with the Mount Manager, CifsManager or via the shell mount command.
Each time the mount command crashes the tablet (immediately black screen) . I need to press the power button for about 10 seconds to reset the tablet and after this i can start the tablet again.
Can any one help me please ?
Originally posted by w4sepp View PostI am trying to mount a windows share by using either with the Mount Manager, CifsManager or via the shell mount command.
There are currently 2266 users online. 0 members and 2266 guests.
