Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by porthos View Postif you appreciate my efforts this is the link for any donation:
Hello,
I just received my PIPO M6 PRO 3G last week, I installed Pipo M6 Pro RileyROM_1.8 KitKat with Kernel kernel_GPS_1.2_cpu1704h_target_2.1_gpu600_ddr744 by the M6 was restarting with the kernel kernel_GPS_1.2_cpu1704h_VERY_LOW_gpu600_ddr744.
The reactivity of the PIPO is much better. With RileyROM_1.8 and kernel I get Antutu 19674
My question would be whether there is an engineer mode as MobileUncle for Rockship? I have problems with 3G passes too often Edge, see loss data connection while my HTC ONE captures very well the 3G.
Sorry for my bad English.
About 3G... you can try a different ram setting like kernel_GPS_1.2_cpu1704h_target_2.1_gpu600_ddr768, to see if 3G will work better!if you appreciate my efforts this is the link for any donation:
Originally posted by nicolachh View PostI have problems with 3G passes too often Edge, see loss data connection while my HTC ONE captures very well the 3G.
Take a look to this post (the libril-rk29 is the same for all Pipo models with KitKat) http://www.freaktab.com/showthread.p...l=1#post155858
or easier, the same in your language: http://tablette-chinoise.net/rileyro...60.html#p56838
Originally posted by manao View PostThis is normal because you have a generic libril-rk29 (modem data connection) on this ROM to preserve the Deep Sleep.
The original kitkat libril is the only one that make 3G usable on our pipo now. The only problem is that deep sleep function will not work.if you appreciate my efforts this is the link for any donation:
Re: Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by porthos View PostI envy you your incredible AnTuTu results - my Pipo M6 pro 3G has never reached 20000 or exceeded this value - 19 741 is a max. I use RR KK1.8 and Giouncino kernel_GPS_1.2_cpu1704h_1325mV_gpu600_ddr744. How you do this?
Besides Art as runtime , there should not be a reason why ucould not reach the 21K mark.
Verstuurd vanaf mijn M6Pro met Tapatalk
Originally posted by porthos View PostThank you Giouncino but nothing changed - antutu score 19561
Wysłane z mojego M6Pro przy użyciu Tapatalka
This is my result with maakie kernel from here: http://www.FreakTab.com/showthread.php?t=11793
Sent from Tapatalk on my m6pro running Riley ROM 1.8 KK
Originally posted by Pipo2000 View Post🙌 could you also post the details of that incredible score ?
Originally posted by Billcnz View PostIt's just RR1.8, ART runtime and maakie kernel with WiFi only m6pro
His version has higer voltages than mine for the CPU and have ram set to [email protected]if you appreciate my efforts this is the link for any donation:
3G
I have tried many times all modes of kernel from giouncino, which I have worked.
3G only works steadily on Pipo M6 Pro RileyROM 1.8 KitKat, not mod.
Also steadily works on 3G kasty-pipo-m6_pro-442-20140213-rooted4_mu.zip.
But this firmware is not for my CPU - it often freezes.
I also really helped mod metal back cover.
I cut a rectangular hole (3x7 cm) opposite 3G antenna.
And placed a strip (5 mm) under the antenna.
I use a case, so the hole is not visible.
Sorry for my bad English too.
I capture the 3G but it will turn off after 1 minute, then back, then switches to 2G.
I am often without signal while without moving just before I captured well.
I have reconfigured the Orange operator parameters.
I test the flow when I have 3G, and it gives:
Download 101 Kb / s
Upload 187 Kb / sLast edited by nicolachh; 24 April 2014, 18:35.
There are currently 1385 users online. 0 members and 1385 guests.
