Pipo M6 Pro RileyROM 1.8 KitKat
Re: Pipo M6 Pro RileyROM 1.8 KitKat
Originally posted by jdv007 View PostGiouncino where do i find this kernel and its description?
Post #711
Sent from Tapatalk on my m6pro running Riley ROM 1.8 KK
Originally posted by Conch View PostHi all,
I've flashed RR 1.8 Kitkat. This system is smooth and more stable than JB. I just wonder how can I unroot this ROM. I want to install AirWatch to connect my company push e-mail but this AirWatch app need unroot system. I've tried on RootCloak without no luck even AirWatch is on the RootCloak compatible list.
Please advise.
Thanks....
You can find it HERE
Good luck!
Originally posted by psxmail View PostCould I enable the ART in this ROM with your firmware Giouncino??
Envoyé de mon M6Pro en utilisant Tapatalk
Originally posted by Billcnz View PostYou can enable ART in developers options then after reboot turn developers options off (ART will stay on). It works with original or modified kernel
Sent from Tapatalk on my m6pro running Riley ROM 1.8 KKif you appreciate my efforts this is the link for any donation:
Hi, I have little problem with flash player. Video is no sync vs audio(has delay +- 2seconds)
I tryed instal few falsh apk from adobe site but problem is not solved....
So i tried JB rom 1.9 today and flash working OK. So I think, problem is 1.8 KK....
Is anybody here with same problem? Any idea for it?
Thanks for help.
H.
miracast and RR KK1.8
Can someone advise me with miracast (wifi display mirroring) and RR KK1.8? I have installed miracast adapter, my pipo connects to it and then when "Ready to display" info appears on TV my tablet reboots every time. I use PipoM6Pro 3G and RR KK1.8. Just checked the same adapter with PipoM9Pro 3G with RR KK3.0 and everything is stable with no issues. Maybe some libs were removed together with WifiDisplay.apk in this ROM?
Originally posted by porthos View PostCan someone advise me with miracast (wifi display mirroring) and RR KK1.8? I have installed miracast adapter, my pipo connects to it and then when "Ready to display" info appears on TV my tablet reboots every time. I use PipoM6Pro 3G and RR KK1.8. Just checked the same adapter with PipoM9Pro 3G with RR KK3.0 and everything is stable with no issues. Maybe some libs were removed together with WifiDisplay.apk in this ROM?
unfortunately it's due by a kernel problem. At the moment there is NO kitkat kernel working with miracast for M6pro.
The only solution is to swtich back to JB.
I'm still waiting for any improvement on the m6pro kitkat kernel to fix this bad issue...if you appreciate my efforts this is the link for any donation:
Problem after flashing
Hi,I'm from Peru, can you help me with this?
I used the RileyROM 1.8 KitKat to flash.
All process was ok. I did the erase nand idb and then the flash. All was green colours.
After, the tablet show me the pipo logo and 4.2.2.
But after some minutes I wondered if this was normal. And I pressed the power button. It went off.
But after I'm trying to turn on, no response. I connect to Pc, don't recognize the tablet.
Connected via usb to pc, If I press power button some seconds, PC try to recognize the usb connection, but after 3-4 secs, it loses the connection as if I had disconnected the cable.
Regards.
Originally posted by logan20m View PostHi,I'm from Peru, can you help me with this?
Regards.
are you completely sure you did everything correctly?if you appreciate my efforts this is the link for any donation:
Regards.
After flashing the first thing that boots is the stock recovery. That's why you see a Pipo logo...but if you successfully flashed the KitKat ROM, it should say 4.4.2...not 4.2.2. You have to give stock recovery enough time to format all of the partitions (you will see activity at the bottom of the screen)
I'm thinking you had a bad USB connection when you were flashing and IDB didn't get erased and the images didn't flash correctly. Are you using the stock USB cable that came with the tablet to flash? That's very important. Also, make sure you are using a USB 2.0 port...not USB 3.0 Try a different. If that doesn't work, try a different PC.Randy
There are currently 2710 users online. 0 members and 2710 guests.
