Here is the KitKat ROM made for the T428.
I could not test everything but I did test a lot of stuff. Remember KitKat is still in development so your mileage may vary.
I have supplied 4 kernels made by D33. Two are for the 3188 and for those that recently got a 3188T those are also supplied.
Hey! TWRP recovery! Abdul did 99.9% of the work on this and I just modified it so it could be flashed with a ROM and also so it then did not mess up when doing a factory reset from Android.
As always READ MY README for more information.
_________________________________________
Features and release notes for my 2.0 ROM:
1) Properly rooted using SuperSU. What does properly mean?
Android 4.4.2 requires SU to be running as a deamon now. There are many ways to run this as a damon.
Most roots so far are using a install-recovery.sh script or if init.d is enabled, a init.d script.
This means you could lose root if messing with these scripts which some rooted apps do!
What I have done is started the damon in init.rc thus eliminating the need for boot scripts!
This took me a while to learn to do! Enjoy a BETTER ROOT!
2) Stock ROM was only 1 Gig of APP space.
BUT you also have parameter file options!
There are also 1gb, 2gb, 4gb and 6gb options.
Read below for how to change that in the flash tool.
I made the default 2GB
3) Debloated of junk APPs and Google Apps you can get from Google Play.
There was quite a few useless hidden apps in this kitkat release! Some of them did not even work.
I also updated Google Play and required Google APPs to the latest versions.
4) As always, full init.d support! If you do not know what that is... ignore it. For geeks that want to use it. It is there!
This time around due to updated security in 4.4, init.d was a lot harder to get working.
Again I had to figure it out!
5) I dumped the crappy modified kitkat launcher that was in this and used the AOSP stock kitkat launcher.
This gives you the transparent status bars back.
6) Rotation is now locked in this ROM
7) Calendar app was not working. I replaced it with the AOSP Google Calendar APP.
8) Build.prop edit to open up the Google Play store to APPs that normally say "not compatible".
I am spoofing a Samsung device that will show almost any APP as compatible.
Your device will show up in google play as Samsung device not a T428 or RKSDK! Understand this please.
I also left the original build.prop in the ROM called build.orig.
If you want to go back, just use ES FIle Explorer or a root file explorer and rename build.prop to build.old
Then rename build.orig to build.prop.
Go into settings, apps, all and go into the Google Play app. Clear the cache and data.
Reboot! You should be back to showing up as a 908.
WARNING if you do this, you need to be using the 1080 kernel or your screen will be oversized!
9) I added a reboot APP that will allow optional reboot options like reboot to bootloader (flash mode).
10) A working TWRP recovery!
Special thanks to Freaktab developer Abdul_pt for working on this. He did all the hard work!
I had to modify it to work fully on this TV stick so it could be flashed with a ROM.
11) Kernel choices:
Special thanks to Freaktab user D33 for making this awesome kernels.
There is a 720 and 1080 3188 kernel OC'ed to 1.8mhz
There are also 720 and 1080 kernels for the 3188T clocked to 1.4mhz
The 720 3188 kernel is the default.
12) Boot choices!
There is a boot720 that is to be used with 720 kernels
OPTIONAL boot1080 that you can use with a 1080 kernel if you want large 720 style desktop icons!
If you use the boot720 with a 1080 kernel you will have smaller icons
DO NOT use the boot1080 with a 720 kernel or your desktop icons will be messed up!!!!
13) Other little fixes here and there.
_________________________________________________
OK on with the ROM.
Here is the link to T428 Finless 2.0 KK ROM
ROM -> Tronsmart T428 Finless 2.0 KitKat ROM (305 megs)
Enjoy,
