NEW - T428 KitKat Finless ROM 2.0
Issue with VPN: custom kernels I built have TUN built in but the stock ones didn't.
Issue with ASIX88179: this is a USB3 chipset device. Stock kernels support ASIX88178/88772 only (USB2). Only my custom kernels support ASIX88179Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostIssue with VPN: custom kernels I built have TUN built in but the stock ones didn't.
if yes, where can i found this kernels?
Look in parent forum (rk3188)
Thread is sticky "Kitkat kernels for all"
For this beta rom use the 2.x or 3.x kernels
Sent from my iPhone using TapatalkMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
It is a ROM based on the beta release of source code so 2.x or 3.x
Using my ipad so apols for any stupid ios spelling 'corrections'Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
You need to search for the fixed boot.img
Donate to Finless
First i dont know were to search en seccond i dont know witch boot.img i need to solve the problem.
please can you help me to find the right kernel and the right boot.img
Thanks in advance.
P.s.
i hope you underdtand my englis, because it is not so good.
Originally posted by flhthemi View PostIf you are trying to use a USB ethernet connector, yes, you do need to go into settings and turn on the ethernet. I cant remember what the menu option is named but it's about the 4th option down from the wifi selection and it is titled something like "more connections" or something like that. When you open that you'll see the tick box for it.
Thanks Bob. You hit a homerun on this one.
Just cant say enough about this one as to how much I like it. Everything worked right the first time right out of the shute. I have had it on non stop now for about 8 hours now just getting all my apps back and setting it up the way I like it and have had no FCs or reboots that I didnt initiate. Will let you know if I find anything not working but so far I'm loving this rom.
One question though, since it has TWRP installed, will we be able to flash diferent kernels with it and will any updates be flashed this way as well?
Thanks again...
found one issue
The one thing that I found that wasn't working for me was the TWRP recovery that was added. It did a backup just fine but when I went to restore, it stopped at recovering data, not able to read to _exSD or something to that effect. I did however, install the Arc tools apk from another post in freektab which allowed me to install a working version of CWM recovery and it is functioning just fine. So now your rom is perfect in my opinion. If I could have got TWRP to work for me I would have kept it as that is my preferred custom recovery and run it on all the Android devices that I own, and thats a lot. My wife hates it, as she thinks I could be spending my money on something "useful" lol..
Originally posted by glockman4519 View PostThe one thing that I found that wasn't working for me was the TWRP recovery that was added. It did a backup just fine but when I went to restore, it stopped at recovering data, not able to read to _exSD or something to that effect. I did however, install the Arc tools apk from another post in freektab which allowed me to install a working version of CWM recovery and it is functioning just fine. So now your rom is perfect in my opinion. If I could have got TWRP to work for me I would have kept it as that is my preferred custom recovery and run it on all the Android devices that I own, and thats a lot. My wife hates it, as she thinks I could be spending my money on something "useful" lol..
Ark tools link
http://www.arctablet.com/blog/forum/...ware-20130613/ this is the link to the software you will need to download. just hit the link at the top for the CWM easy recovery instal and it will guide you through it. If you still have any issues I can try to find the apk link itself. you just instal the APK filewhich is Arctools, It is an application like rom manager or Goo manager in that it will download and instal the recovery for you, Here is the link that will take you to the Arc tools download page, just go to this thread and in the side bar you will see the download link to the Arc tool, hit it and it will start the download automatically. http://www.arctablet.com/blog/downlo....arctools.apk/ I hope this helps, give me a yell if you need anything else.
There are currently 2166 users online. 0 members and 2166 guests.
