NEW - T428 KitKat Finless ROM 2.0
Originally posted by glockman4519 View PostPlease consider making a Donation to freakTab
Originally posted by repulse View PostThe thing is that it's impossible to load the recovery when the system doesn't boot (infinite loop, etc...), the only physical button is for booting into bootloader.
Anyway, there is no KitKat rom for our devices flashable from any recovery, right?
Recovery boot
Originally posted by glockman4519 View PostYou can download an app from the Play Store called "Quick Boot" and this will let you boot directly into recovery. Also, if you download and install the "Arc Tool " package that you can find in this fourum, that tool kit will also allow you to boot directly into recovery.
Originally posted by torosauro View PostI have installed this rom but it cannot read the external SD card that is working on other devices.
Can it be a flash problem?
R: NEW - T428 KitKat Finless ROM 2.0
Originally posted by nickyp View PostMine reads a 16gb card no problem. I presume you've tried cleaning the contacts on the card? What size card (how many gb) are you trying? It could be that you're over the max size that is supported - I don't know what that is, but worth checking.
I have tried to flash it again the rom but when I start the device, android do ask me to re-configure it.
Originally posted by torosauro View PostI have tried 2 different SD card (one 2gb and one 8gb) with the same result. When I type settings-memory it reads the card but when I download apk (I have tried only to do that) it say "to download this you need an SD card"
Originally posted by nickyp View PostNot sure what you are saying - you can or cannot read the card? Anyway try a different download manager (eg Advanced Download Manager) and specify the download location. Actually the stock "Download" app on this Rom doesn't work for me at all (crashes).
Bad WiFi signal...
Hi all,
I have just installed this ROM, and I was very happy because it looked very fast but, unfortunately, when I tried to watch a video in streaming I noticed that the WiFi bandwidth was very low! The device is in the same position of yesterday - when I was mounting a 4.1 ROM - and although yesterday I could "see" 6-7 WiFi networks nearby, today, with this new ROM, I can barely see mine + another one (I changed nothing but the ROM). The download speed changed from almost 8 Mbit to 0.5 - 1 Mbit, so that even the worst quality video on YouTube buffers several timesAnyone is/was experimenting this kind of issue? any option/idea in order to improve the speed (I don't have the router in the same room so I cant go with wires)? I am not that happy to go back to 4.1 ROM but, at the moment, since I use this device mainly for streaming, with this ROM is useless
ps: I used the 1080 kernel (KK_RK3188_1080_v01.02) and the 4GB parameter file
Thank you.
Thank you.
Also note that going from a Kitkat ROM back to Jellybean ROM requires some additional work.FLHT = Harley
HEMI = 2010 Dodge Challenger SRT
Cause I've been asked.
Originally posted by flhthemi View PostTry looking in settings for something like "optimize wifi" and turn it off. Might make a difference.
Oh, I knew that for Samsung devices, but I didnt know this device kernel was locked as well.
So , I guess, I need to start checking for a new device to buy...
UPDATE: I just down-clocked the kernel to 1200 from 1800 MHz and I reached 7 Mbit in download. I am wondering if the WiFi problem would be power related. At the moment I am using the standard 2A charger...Last edited by Breath; 03 January 2015, 22:16.
Originally posted by Breath View PostHi, thank you for your reply! Yes. I already did it but unfortunately nothing changed.
Maybe try the 720 img files just to see if it changes.
New device: I just did this last night. Ordered a Zotac Zbox BI320-U-W2. Tired of fussing with android...this comes preinstalled with Win 8.1, 2gb memory and a 64gb SSD.FLHT = Harley
Crapware inside?
My firewall blocks about 2000 outgoing connections attempts per hour. That is to say when idle, not trying to do anything.
Looking further into it seems to be coming from the kernel. The same after re-flasing the stick (default settings: 720p rk3188, 2gb).
Has anyone else experienced this?
Hi there, thats seccound rom ive tried so far.
That looks great and its smoother than finless 1.5 ive tried but I have one issue.
On finless 2.0 wifi works very slow for me ( it worked very good on 1.5) there is also imposiible to instal any bigger app becouse google play stops to download after few %...
I want to ask if there is any way to flash different kernel only and if this can fix my problem.
I have Tronsmart t428 running Finless 2.0 in deaufult configuration.
My internet is superfast so there is no problem with broadband.
I will appreciate any help.
Thank You.
There are currently 2289 users online. 0 members and 2289 guests.
