NEW - T428 KitKat Finless ROM 2.0
Thank you very much Bob for your new ROM. I have just downloaded it, however would it be possible to also include a md5 check sum in the first post. I always like to see if something happened during the download before I flash something.
Regardless as soon as I try it I will post here some feedback.
Many thanks once again and enjoy the weeked :P
Originally posted by vnishimoto View PostI discovered this happen only when I use fixed IP over ethernet. This not occours in WI-FI
I installed the KK Finless last night. Bob's instructions in the zip file are perfect and if followed to the "T" will get even a n00b like myself an excellent OS on their T428! One thing to note if you already installed the Finless 1.5a and IF you left the drivers installed on your PC, you do not need to install them again and you can go right to flashing (Bob if this is wrong let us know). You'll know they are there if you hear the USB tone when you put the 428 in flash mode, open device manager and see NO errors reported. Then when you run the flash tool you'll see at the bottom (as per instructions) it was recognized. If you don't see that then install the drivers anyway. I got a little panicky, I was using a Vizio PC monitor with HDMI to watch things and wait for the 1st boot. When the 1st boot came the screen was flashing on/off as if the HDMI hand shaking wasn't going well. So I just waited and saw the setup screen flash on/off the screen a couple times and figured it made it to boot. I moved the 428 to a TV re-booted and there she was!
It is way better than the Finless 1.5a and that was damn good!
Do need volume control fixed but I understand and still think it's WELL worth installing.
Would also be great to see the static IP bug fixed but can live with the work around.
Oh, what if I wanted to use the 1080 (larger icons?) now that I've already flashed the 720? Can I just install it over the 720 and not loose any data on the device or do I need to start all over again?
Now....in KitKat how do they power off the 428? I can't find a power off button other than what Bob has supplied us with (there's an app for that!) and now I'm just being curious. I'm supposing you would use the physical power button on the device (we don't have one on the 428).
Many, many thanks Mr. Finless for fixing my T428 and making it work like you would think it should!Last edited by flhthemi; 08 March 2014, 14:46.FLHT = Harley
HEMI = 2010 Dodge Challenger SRT
Cause I've been asked.
Originally posted by flhthemi View PostOh, what if I wanted to use the 1080 (larger icons?) now that I've already flashed the 720? Can I just install it over the 720 and not loose any data on the device or do I need to start all over again?
New kernels click here
Compiled for T / non-T and with optional 1.8V lcd setting to stop flickeringMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
I have my 428 in flash mode on my USB port. When I run the Android tool and it opens is it displaying the current boot info for the 428 or defaults from the config file?
Can I change BOTH kernel and boot image and loose no data?
How do I get out of flash mode if I don't flash anything? Just pull the plug?
That's where I am right now and I want to make sure I don't brick this thing with the wrong combination.
Old fart can't remember which kernal img I flashed. I need to change it so I can see the bigger icons I'm going blind trying to read the stuff on the screengod I hate getting old.....
FLHT = Harley
When you run the flash tool the line represent what's in the config file not whats in the ROM.
Yes you can flash kernel and boot and not loose data.
Originally posted by Finless View PostWhen you run the flash tool the line represent what's in the config file not whats in the ROM.
BobFLHT = Harley
Originally posted by AccordXTC View PostHas anyone or know if its possible to get 5.1 off the HDMI. Everything is great with this firmware if only could get 5.1 I'd be perfect.
ThanksT428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
There are currently 2708 users online. 1 members and 2707 guests.
