Any solution for this?
HardwareGuru Rom 04 - Firmware for Neo X7
Originally posted by jjeroen View PostHi guys, I've installed Beta: 04a.Rev2 and downloaded the dutch broadcasting app NPO. While the version specifices the NPO app working, mine still buffers and stutters after 10min. Within XBMC, the NPO plugin works fine.
NPO app either stays playing at the very lowest quality (not detecting it can achieve higher bitrates). Or it hangs when trying to switch to a higher bitrate dynamically. Same goes for RTL XL, NPO websites (3fm), etc.
Everything that depends on the libmedia framework shows this behavior. XBMC and Netflix seem to have their own media handling code, which results in them not having problems.
hi
i got a other question:
i want to know in which way does the rom automount external hdds?
i know all the ways to automount external sources ;D
so pls dont post them.
i want to use "stickmount pro"
---> http://forum.xda-developers.com/galaxy-nexus/themes-apps/02-11-2013-stickmount-v2-30-t1400034
on hardwareguru rom so i want to know if some apps conflict with stickmount.
i deleted -> airdroid,bsplayer,airpin
are the some other apps which automounts be dafault?
or a script inside the rom?
i have to disable all the apps/scripts that automount.
reason?
i want that the rom automount all my hdds everytime it starts.
and!! i want that the rom mounts it everytime the SAME way,so all paths are the same.
because sometimes when i reboot the rom some paths are not the same as before and then i have to connect some hdds again and have to relocate the movies -.-
annoying!!!
stickmount pro is known for mounting the hdds with specific labels and specific paths.
Pro) Mount as partition label
Instead of using the block device name (sda1, sda2, sdb1, etc) for the partition, use the partition label as mount name. If the label is not available, fall back to the partition uuid (unique id). Only if that is not available either, use the block device name as mount.
This helps to keep your files in the same and easily identifiable place!
so i only want to use THIS app to automount my hdds.
thx in advance
New Stable Release ROM?
Originally posted by HardwareGuru View PostHey guys .. too much posts to awnser for me now. At the moment i am in hong kong for the global sourcing fair to meet some manufacturers (and have a good time). Will be back in the netherlands on thusday and will scroll back this thread then to give some input on your questions
Verstuurd vanaf mijn GT-I9105P met Tapatalk
Guest
yeah
He (and the rest) is doing it in SPARETIME..
imagine being satisfied with the STANDARD firmware from Minix, they should have provided a "perfect" firmware from the beginning eh ? - then maybe all this was not even THAT nescessary
Guess not.
I am very grateful for all the work from team Nitro, Finless BoB, Flumpster, Hardwareguru, Lewy, Stafstrom and especially Kyoing for putting all this NON PAID work into it.
which is why i recommend donations and respect to the time it takes..
just my 50 cents greasing up the developers :P
Originally posted by Theklavej View PostHe (and the rest) is doing it in SPARETIME..
Guess not.
just my 50 cents greasing up the developers :PTo Infinity and Beyond.... XBMC
Originally posted by Theklavej View Posttrue true wasser too :P
im just extremely happy
which reminds me, flumpster are you going to flumpsterize gotham ?To Infinity and Beyond.... XBMC
Guest
Hi HardwareGuru,
Did you manage to have to progress with getting HSL Smoothstreaming running on this box? I Remember you working on this and had some beta in which it was working properly.
Would love to know what you already tried to we can use this and try it out on the kitkat roms currently available. Let me know
Dankje!
can i use "build.prop.no_overlay_small_icons_quickflashe r" ? As i need smaller icons, even 1080p is way too big in Projector screen. Or how to make it bit smaller?
i use this one "http://xbmc.hardwareguru.nl/Guru_X7_1080p_preloaded_04c_malipatch_public.zip"
ThanksAndroid devices: Minix X7 (gone) , Minix X8-H , MK808b Plus
Video Out: Benq W1000+ 1080p Projector
Audio Out: HDMI -> Yamaha RX-V467B + 5.1 Yamaha Speakers
Remote: Rikomagic MK702 II, Minix NEO M1
Storage: NAS Zyxel NSA325v2
There are currently 2444 users online. 0 members and 2444 guests.
