HardwareGuru Rom 04 - Firmware for Neo X7
    I'm thinking of changing from Quickshot V2 rooted to this.
    Is it possible or hard to do? Could some one pretty please post some sort of short tutorial with key-elements included.
    I don't have much experience with changing roms / updating etc. Looking for the easiest method. I'm running Windows 8.1 currently on my main PC but I guess I could borrow a XP/win7 laptop somewhere if it's not possible to do otherwise or without using PC.
      find "rkbatchtool" open the *.img and hit restore
      Android devices: Minix X7 (gone) , Minix X8-H , MK808b Plus
      Video Out: Benq W1000+ 1080p Projector
      Audio Out: HDMI -> Yamaha RX-V467B + 5.1 Yamaha Speakers
      Remote: Rikomagic MK702 II, Minix NEO M1
      Storage: NAS Zyxel NSA325v2
        I am on Beta: 04a.Rev2 and all working good. Best rom for me now. :-)
          Hey guru hope alls well your side of pond! maybe when your not too busy plugging holes in the x7 dyke you can build rom for mk902 with d33 new kernel from post 994 in kitkat for all thread
          LOL Fyi. Thanks for the build because Karal posted new x5 that has kernel from minix and your rom and it fricking Rocks! Now i want same for the mk902, ill pull yours apart and swap kernel out and post what results i get.
          Minix send your check yet?
          Keep well !
            cannot flash with rkbatch tool
            Since i've installed the hwg rom, I cannot connect with PC anymore (after reset) and restore / flash img with new rom. All I can see is an option menu to reboot to some different modes, reset to factory settings, etc, but there is no way I can get back the device connect to my PC (with otg cable). Anyone helP?
              Hello all,
              Good to see my rom here is still working out great
              Luckaly i have more work then time.
              So please forgive me for not beeing arround as much as i would like to be.
              Just a sidenote...I have made some transulations for the new X8 firmware on request for minix too
              We are working to make new firmwares for the entire minix collection wich will be finalized at the end of next week.
              We then will release a "public edition" of the 005 for the X7 after that.
              We try to get HLS fully supported, at the moment it will not allways work.
              I will see what additional features will be included into the 005 public edition.
              Stay tuned and thanks for all the feedback !
              @scooter2014
              Good to see they work on the X5 rom
              I just posted a reply there.
              See you arround mate!
              @ mcauseway
              in android Settings : enable USB, usb debugging and set storrage to MTP
                Thnx for all the time and effort, loving the work you put out there for us to enjoy!
                Sent from my GT-I9300 using Tapatalk
                  Thanks mate and can't wait to test your next rom .. I am still using your rom and loving it. because its a simply the best !!! and most of all its a trouble free ... cheers geeza
                    Awsome news let me know what needs testing on x5 or x5 mini :-) glad to pitch in
                      progres report ??
                      Love your rom
                      any progres on report on the 005 ???
                        has anyone here guruxbmc?
                        I want to test with the guru firmware.
                          I am working on a new HLS patch.
                          Please let me know wich apps do not work yet so i can test them.
                          HWG
                            Re: HardwareGuru Rom 04 - Firmware for Neo X7
                            HWG
                            Hi Guru, not sure if you are able to test but what about the ds synology apps? for example the audio? The old Guru fw works but the audio app does not work at karels his fw.
                            If you cannot test ask me and I can do it.
                            thx
                            Verstuurd vanaf mijn ME173X met Tapatalk
                              thx
                              You will be the first one to test it
                                great thx !
                                Verstuurd vanaf mijn GT-I9070 met Tapatalk
