Pipo M7 Pro RileyROM 2.7 KitKat
Originally posted by Dennta View Post
Re: Pipo M7 Pro RileyROM 2.7 KitKat
Originally posted by thehobit View PostThanks for the ROM. It runs smoothly other than the Wi-Fi which mostly can't connect at all after the device is waking up from a sleep (I'm using kernel_cpu1416h_gpu600_ddr720.img).
Any hint? Thanks.Randy
Originally posted by charczstrife View PostI've been using katsy ROM for awhile for this tab
Originally posted by charczstrife View PostDo I need to flash to stock ROM first before flashing this ROM?
Thanks!
Originally posted by charczstrife View PostGuys, i've been using katsy ROM for awhile for this tab now and im planning to use this ROM now(as far as I've seen, this the most stable Kitkat ROM as far as comments show). Do I need to flash to stock ROM first before flashing this ROM?
Thanks!
no, you don´t have to go back to stock ROM but read always thread 1 posted by Randy just to make sure you don´t act to easily flashing any ROMs. Have fun with that really good ROM compiled by Randy.
Cheers,
Franky
Cheers,
Franky
Thanks!Originally posted by fazerg View PostAnd there is still no his ROM for this version?
You don't have to flash the stock ROM before flashing a custom ROM. I don't know where that thinking was ever started, it just isn't necessary. But you do need to do your homework first. Make sure you flash the loader along with the ROM if you are flashing a KitKat ROM. In this case, Pipo updated the loader, too...so I advise flashing the new loader with this ROM.Randy
Originally posted by rrileypm View PostCheck your router settings...and maybe try a different channel. You may also have the dreaded wifi antenna problem with the solder connections shorted.
I'm not sure its smart to mix but so far so good.
There are currently 1976 users online. 0 members and 1976 guests.
