Pipo M7 Pro RileyROM 2.7 KitKat
Hi!
I have a problem with the wifi since I installed this ROM. It worked fine since yesterday with the original configuration, but since I installed the new ROM it only can connect to the wifi network for a short time once after it restarts and then it is not possible to connect again.
What can I do to solve it?
Anyway, thanks for the ROM, while it works it does really well!
I've searched a little but do not find any solution specific for the M7... HELP PLEASE!
Try this:
Randy
I was just trying this... but I can't get in flash mode... for the M7 the key combination is power+ESC but it doesn't get in flash mode...
Click the reset hole with a paperclip. Then try it.
Check your USB connection.Randy
Originally posted by rrileypm View PostClick the reset hole with a paperclip. Then try it.
To get out of the screen with the dead android I have to reset with a paperclip. Then it stays all disconnected and does not respond to the buttons. I have to press for long time Power and it turns on, but in about 5 seconds the screen with the dead android appears again.
I keep pressing ESC+Power once it has turned on but the Flash Tool does not recognise the tablet and keeps saying "No Found RKAndroid rock usb".
The USB cable is well connected both in the tablet and in the computer and I've tried to get in Flash mode with the cable connected and disconnected.
I don't know what to try anymore...
Originally posted by charczstrife View Post1There's no portrait mode when Im on homescreen and appscreen even though AutoRotation is enabled. But when Im using an application like 'Office' or 'Youtube' or even 'Settings', the screen switches to the landscape to portrait mode and vise versa when I flip it. Its just on homescreen and apps-screen that does not.
Any fix on this one?
Hi again...
I've been trying everything but nothing worked so far.
I can't get it in flash mode and consequently I can't do anything. When it reboots it takes only a few seconds before the "dead android" screen appears and it is too short to put it in flash mode with the buttons and also too short to be recognised by the computer and put it in flash mode with the flash tool.
Any idea?
Thanks in advance
Sorry for redundancy here...but may I ask.....
Are you using the same PC you originally used to flash the ROM?
Are you using the original USB cable that came with the tablet...yes it makes a difference, the connector is longer to fit better inside the tablet.
Are you connected to a USB 2.0 port...3.0 won't work. Also, don't go through a hub.
Once you are convinced you have a good USB connection try holding escape and power to get into flash mode. You might need to press reset first to make sure the tablet is off.
If none of these work, then you are in a bricked state and will need to get into mask mode by shorting some pins on the NAND chip. They might not be 7 and 8...it could be 6-7 or 8-9. You might need to hold down the power button to keep the tablet on for this. There's a sticky in the Pipo section with pictures if you need them.Randy
Originally posted by Aiz View PostI keep pressing ESC+Power once it has turned on but the Flash Tool does not recognise the tablet and keeps saying "No Found RKAndroid rock usb".
- Let your tablet off
- connect your tablet off to your PC
- open the flash tool
- tablet off you click at the same time to ESC + Power
The flash tool reconize your tablet
- erase IDB
- flash ROMLast edited by manao; 20 March 2014, 08:38.
Thanks riley!
Originally posted by rrileypm View PostSorry for redundancy here...but may I ask.....
There are currently 2063 users online. 3 members and 2060 guests.
