Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
    Hello Guys,
    Here it is the New Neomode Custom Rom for the MK809III with Android 4.4.2.
    Have Tested this Rom and everything Works like it should with MK809III Version 2 & 3.
    The Rom comes with a SD Kernel and a DPI Setting of 160 and is Rooted.
    What Works ?
    - WiFi
    - Bluetooth
    - Rotation
    - USB
    - USB OTG
    Software Included:
    No-Frills CPU Control
    Reboot App from Petrus
    SuperSU (Root Access)
    Terminal Emulator
    FX FileExplorer
    Chrome
    Chrome UA
    This Time the Rom has a Lot of new Features:
    Volume Slider Works
    Added Power Down Button to Navbar
    Hide Navbar Button (Re enable it with Sliding from Top to Bottom)
    5Point1 Multichannel
    HDMI Passthrough
    OC Kernels Included
    (To Flash a OC Kernel press the Button in RKFlash Tool where Kernel is then you can Selec New Kernels from OCKernel Dir.)
    1,2,4,6 GB Parameter Files Select before Flashing
    Download:
    New Version:
    Upload running please wait 1h.
    Old Version:
    Regards
    Neomode
    Originally posted by neomode View Post
    Hello Guys,
    I have ported this Rom from Tronsmart A928 Rom.
    The Rom comes with a FullHD Kernel and a DPI Setting of 240 and is Rooted.
    What Works ?
    - WiFi
    - Bluetooth
    - Rotation
    - USB
    - USB OTG
    What not Work ?
    You tell me please
    The Rom comes with the awesome Kernel from D33 thank you !!
    I have only included FreakBrowser a WebBrowser and datFM a File Manager.
    Download:
    Upload Running please wait a half hour to finish. 27.03.2014 - 11.30 CET
    Regards
    Neomode
    how about MK802IV?
      Will be the Next one, working on it right now.
      Neomode
        Neomode
        sorry i posted wrong model.. so i meaned MK802IV
          I know what you mean ;-)
          Neomode
            Neomode
            thanks, youre the best!
              Neo, will it works with MK809IV ?
                Will backup and test it
                Will backup and test it on my CX 919
                My Setup (can't yet put it in signature)
                CX 919 (3/32014) + Tronsmart TSM01 - Rom Neomode 1.9
                Nikon D80 Photographer
                Eye for the Art.
                __________________________________________________ ________________________
                CX 919 - Rockchip RK3188T 1.4 GHz & AP6210 WiFi ( Date 3-3-2014) + Tronsmart TSM01 Rom using: Testing.
                  AW: Neomode Custom Rom MK809III Version 3.0 Android 4.4.2 FullHD
                  Don't know because i have no Test Object. Sorry.
                  Neomode
                    I've not read all the posts in this forum yet but are there any installation instructions I could read?
                      Depends on the dongle... I supose
                      Eye for the Art.
                        support Ap6210 ????
                          Originally posted by endera View Post
                          support Ap6210 ????
                          I think so. As soon as I test in my cx 919 I'll confirm it.
                          Eye for the Art.
                            i need help
                            Sorry, I'm using google translator.
                            that would actually stand me a link to the tutorial how to install this version with wifi, bt. I installed other versions and could not get over the Wifi work if you can help me.
                              Upload finished.
                              Neomode
