Neo, thank you for finally creating ROM which is stable on my device MK809 III/ AP 6210. Have tested 720p on XBMC via Ice Films and I can confirm everything finally runs smoothly, which is why I bought the device in the first place. The only thing that bothers me is that I have to open a case of the device in order for WIFI to run smoothly (without that - connection drops from 65mbps to 5mbps) but as long there is a workaround I'm happy with it. I have to say that I had 3 identical versions of MK 809 III in the last six months and each device had different issues with identical roms even though their internal chip was the same, therefore I think there is no ROM out which would suit everyones device even though specs are the same.
I also noticed that this ROM has no option to hide the bottom systembar which is kind of anoying when watching movies, but I then found a solution and installed "fullscreen" app from google play and was finally able to disable it, so no more issues there.
