Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
    Originally posted by Nelton View Post
    Sorry, I'm using google translator.
    that would actually stand me a link to the tutorial how to install this version with wifi, bt. I installed other versions and could not get over the Wifi work if you can help me.
    Here you find how to Install that Rom --> http://www.freaktab.com/showthread.p...hlight=Neomode
    Neomode
      error
      Neomode
      i got that error.
      what I have to do?
      i'm using the MK809 III
        Neomode Custom Rom MK809III Version 3.0 Android 4.4.2 FullHD
        Wifi is connecting, but stopps pulling data after a couple of seconds. Was working ok in 2.1.
          sound issue
          Hi Neomode,
          Many thanks for your 3.0 release. Everything is OKay on my initial run and the video is played smoothly.
          However, there is one minor defect on the sound adjustment. It only has maximum or no sound (by clicking the speaker+/- at the bottom row of the screen). In addition, the sound comes out is quite distorted and difficult to listen to any music. There is no way in the Setting/Sound to rectify it. Please advise how to adjust it back .
          Many thanks
          BC
            Upload finished.
            Neomode
            As always...
            NEOMODE 1000Thanks for your support and excellent work!!!
            I had been using without any problems the Neomode 1.9a with OC2 and 4GB Parameter File, so I will backup (with Ultimate Backup) and test it on my CX-919 V2.0 when I get home...
            However since apparently you have not include the 2-4-6 parameter files, I would like to know if I will have to use the Old 4GB Parameter File from the 1.9a Package, to get the same 4GB that I have before?
            Again Neomode, Thanks for always help us with all our requets!!
              Originally posted by deepspace View Post
              Will backup and test it on my CX 919
              My Setup (can't yet put it in signature)
              CX 919 (3/32014) + Tronsmart TSM01 - Rom Neomode 1.9
              Hi deepspace,
              I had been using without problems Neomode's 1.9a with 4GB Parameter File, as you I also will backup (with Ultimate Backup) and test it on my CX-919 V2.0 when I get home, so if you installed first, I would greatly appreciate that you let us know how it works in your CX-919 !
                Hello Guys,
                Thanks for your Words, I noticed the Failure and will keep Updating the Rom.
                The Sound Slider i know and have forget about it my failure.
                Will see that i can fix it.
                Also the Parameter Files i will Upload / Link.
                Neomode
                  Works on mk809ii chip 3188T?
                    Yes it Works on T and non T Cpu.
                    Neomode
                      thank!
                      Wow thanks! Download!! Report in hours
                        Hello Guys,
                        Neomode
                        Thanks Neomode for your fast reply!
                        Hope that you could find and fix the little errors
                        I will wait that you upload the parameter Files, to install and test your new ROM in my CX-919 V2.0 FULL RK3188 (Not "T").
                          Originally posted by ulises1954 View Post
                          Hi deepspace,
                          So can you full backup your rom with ultimate backup? Or is it just the apps+data like Titanium backup?
                            Old wifi?
                            It works for old wifi mk809III device?
                              Not a full Backup of the ROM...
                              Just the User and system apps+data, like Titanium backup.
                                Error on 3188T wifi ap6210 in Mask and loader mode
ID:	433359Click image for larger version
                                I have that error i test in Mask mode and loader mode error is persistent help me ):
