Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
Originally posted by neomode View PostBe my Guinea Pig try it please on your Device !
Neomode
EDIT: Must wait for the upload to complete, got a corrupt file... xD
Originally posted by Skyback View PostDownloading it right now! Just to be sure the file is 248MB right? And is it supposed to work on MK802IV? (actually my stick is a CloudnetGo CR9 with AP6210).
Maybe upload incomplete yet.
Edit..Yes that apears to be the case upload wasn't complete yet.Last edited by Magnus33; 06 April 2014, 01:59.Mk802IV Neomode 1.9a original rom 720p
Having trouble making RKAndroidTool detect my stick... Rebooted into bootloader but my Windows 8.1 is having trouble detecting it... On USB2.0 it says it has a problem, on USB3.0 it detects the device as Rockchip but the tool says "No Found RKAndroid rock usb"... Time for searching! xD
EDIT:
Solved the issue by following this: http://www.freaktab.com/showthread.p...l=1#post100181
Flashed the rom successfully but can't test it until tomorrow...
Running on Mk802IV/SB and its running fine.
Sound slider works now
Hider button working
Sound options seem to be working.
Smooth and happy.
Camera no idea yet.
Edit T kernels not correct example 1608 stock gpu ddr667 shows 1.2ghz to 1.4 ghz
D33 v3.0 Kernels get around this issue.Last edited by Magnus33; 06 April 2014, 03:34.Mk802IV Neomode 1.9a original rom 720p
What do you mean? I still wont be able to oc my mk809iii with RK3188-T chipset? Or can I just use a D33 oc kernel and still enjoy all the new fixes in 3.1?
Best regards,
FredrikMK809III RK3188-T AP6210 running Neomode 3.1
Best regards,
Fredrik
This could be isolated to the MK802IV/sb models but i kind of doubt it.
Yes you can use D33 kernels with this neo rom goodness and so far i seen no issues.
Sound options all seem to work, sound slider works.
Hide status bar button works fine.
All other options working great.
No time to check is camera's supported yet.Mk802IV Neomode 1.9a original rom 720p
Originally posted by Magnus33 View PostThe kernels included clock from 1.2ghz - 1.4ghz for the model T cpu.
Just to be sure I get the right kernels. Is this the correct place to get them from (see link below). And then go for the NODERAT kernel link?
http://www.freaktab.com/showthread.p...All-(well-most!)MK809III RK3188-T AP6210 running Neomode 3.1
A few problems left
Hi Neomode,
first, thanks for this great rom. Using Version 3.1!
There are only 4 problems left with my CX-919 Stick.
The first 2 are 'memory' related.
-Android doesn't remember 2 settings after rebooting.
1. Sound Device (Each boot i have to set audio device from Modiotek USB Headset to RK-HDMI-I2S)
2. And it doesn't remember Screen Scale setting. Each boot i have to configure screen scale.
3. Reboot App doesn't work. Tried to reboot -> System hangs
4. The Bootscreen appears only for one second, then blackscreen until 'Desktop' appears.
(Not really a problem, but a little confusing when booting the system.-> Hanging or working???)
That's it. Would be nice if you could please fix these bugs, because it's a great rom. I like it.
By the Way, someone using XBMC 13 Beta 3? It's working really good now. But i'm a little confused with the resolution xbmc uses. Because it's always 1280x720. I can't change it. When i set the resolution in Android to 1920x1020, XBMC still shows 1280x720p and i can't set it to 1080p.
Is this a bug in XBMC or is it related to this rom?
AW: Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
Hello Guys,
Now I need your Help.
I have tested this ROM with Darrell's 3.xx Kernels but for me it not Boot on my MK809III. I need Information on which Stick it Works.
Second the Reboot App works for me with the Original Kernel. Means it can be a Kernel problem related to Darrell's Kernels.
Neomode
Originally posted by Stuckmojo667 View Post...4. The Bootscreen appears only for one second, then blackscreen until 'Desktop' appears.
(Not really a problem, but a little confusing when booting the system.-> Hanging or working???)...
UPD: why is not have builtin keyboard app, only voice input ?Last edited by privet; 06 April 2014, 10:49.
Neomode
There are currently 3380 users online. 0 members and 3380 guests.
