Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
Anyone else have this issue? Is it a bug in the new rom?
Running 3.1 rom, on the settings/keyboard & input methods section. I have only Google voice typing listed. It's causing an error message, Can't reach Google at the moment, when I try to enter text and there is no on screen keyboard displayed, just a microphone.
My other identical stick (running Neomode 1.7 rom) has Android keyboard (AOSP), Google voice typing and null keyboard V2 listed and everything works correctly.HK1 Pro Plus
FlowFon F1
H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
MXQ Pro+
R-TVBOX Mini+
MK809III
Originally posted by imaddiced2u View PostAnyone else have this issue? Is it a bug in the new rom?
My other identical stick (running Neomode 1.7 rom) has Android keyboard (AOSP), Google voice typing and null keyboard V2 listed and everything works correctly.Mk802IV Neomode 1.9a original rom 720p
Originally posted by Magnus33 View PostJust download a keybaord there loads in playstore.
Another question if you don't mind,
I used 6gb parameter file but I don't think it's working right, when I open the Fx app Media Card shows only 312MB but when I go to settings/storage I see internal storage total space 5.91GB and the NAND Flash shows 312MB. I quickly run out of space after a few downloads, then downloads become unsuccessful even though Internal storage shows 5.40GB Available. Nand Flash then shows only 16.49MB available. So I think the system is not using the extra space or am I missing something. This was happening in the Neomode 1.7 too though.
Thanks Magnus33HK1 Pro Plus
FlowFon F1
MXQ Pro+
R-TVBOX Mini+
MK809III
Originally posted by Fredrik View PostAre you getting DD/DTS-passtrough in XBMC?
/Fredrik
Originally posted by imaddiced2u View PostOk, I assumed it would work like the 1.7 rom, I didn't have to download any keyboard for that rom.
Thanks Magnus33
Remeber though this was not made for the mk802IV so there may be some small bugs.
The devices just happen to be so simlar that this one works great.Mk802IV Neomode 1.9a original rom 720p
This rom works great for me with stock kernel. Thanks to Neo. But Neo oc kernels don't work with my unit. Min CPU and Max CPU set to 1,2 GHz with no change possible. DDR et GPU clock seems to be as stock even if I choose an overclocked one.
With d33 kernels, cpu clock is changed but performances in real life are just horrible.
Neo, will you upload new kernels ?MK809 III - Geekbuying december 2013
Originally posted by Magnus33 View PostNot sure since tend to just use 2g myself which is enough for my apps
If I could move the downloads folder from NAND flash to the Internal storage area it would solve my problem. Right now once the 226 MB of available NAND flash is full my downloads fail even though I have 5.29GB of Internal storage available. Any ideas?
I tried a couple of the OC kernels and they do 1.2-1.2 Ghz on my stick while the default kernel goes 312Mhz-1.416Ghz so I'm using the default for now.HK1 Pro Plus
FlowFon F1
MXQ Pro+
R-TVBOX Mini+
MK809III
Originally posted by imaddiced2u View PostThanks Magnus, I have 2X MK809III sticks, supposed to have 8GB rom in them. I just noticed that some apps are using some of the extra internal storage space and I was able to go into Settings/Apps and click Move to SD card on some apps which moved them to internal storage.
Try dolphin browser for browser downloads as it lets you chose where to save downloads.
Yeah the overclocking kernels are rather messed up for this device but i expect ones that come with neo mk802IV rom when he releases it shall work fine.Mk802IV Neomode 1.9a original rom 720p
Originally posted by Magnus33 View PostTry dolphin browser for browser downloads as it lets you chose where to save downloads.
Yeah the overclocking kernels are rather messed up for this device but i expect ones that come with neo mk802IV rom when he releases it shall work fine.HK1 Pro Plus
FlowFon F1
MXQ Pro+
R-TVBOX Mini+
MK809III
Originally posted by imaddiced2u View PostThanks bud, You probably don't remember but You pointed me to the 1.7 rom and OC kernels that worked great, thanks again, I appreciate it
I remember basically because iam from Sydney NS (ways back when) so it stuck in my brainMk802IV Neomode 1.9a original rom 720p
There are currently 2212 users online. 1 members and 2211 guests.
