Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
    To activate play store, go to "Parameters" and "Accounts"
    Click on "+ Add account", create a google one.
    You should have the "Can't reach google" message but if you input your login and then hit "Tab", you could input your psw. Then, just hit "Enter" and it should work.
    MK809 III - Geekbuying december 2013
      Could someone upload the System.UI of V3.1 for me...
      I would like to test it on V3.0.
      This because v3.1 doesn work atm on my CX-919
      Thx. in advance
        You should have the "Can't reach google" message but if you input your login and psw and then hit "Enter" it should work.
        Thanks for that, That got playstore to work, the password field kept going away when the can't reach google at the moment error popped up but I eventually got it to take it. I think because only Google voice typing is in keyboard and input methods. Plus I don't get an on screen keyboard.
        Shouldn't there be more items in settings/keyboard & input methods section. My other stick (still running Neomode 1.7 rom) has Android keyboard (AOSP), Google voice typing and null keyboard V2 listed. It has an ipazzport remote connected as well.
        For some reason the 3.1 rom thinks I only have google voice typing as input device.
        EDIT:
        The can't reach google message is coming up everywhere I need to enter text.
        HK1 Pro Plus
        FlowFon F1
        H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
        MXQ Pro+
        R-TVBOX Mini+
        MK809III
          Also thx.
          I got that error also, thats why I switched back to v3.0.
            old old old
            Originally posted by ElHartoshke View Post
            Will it work on the "old" wifi chip? (the RT 8188 one)
            i have old wifi, the stick wil work, but no wifi and BT
              I see, so this is for the AP "new" wifi chip... will repacling the kernel to one of D33 ones will suffice for the old wifi chip to work?
                Originally posted by Fredrik View Post
                So what happens when I play a 1080p movie? ...
                this is the same if your tv supports only 720 HD ready and you play a 1080 movie
                  you need to use this 720P kernel RTL8188eu ( this one only works for me )
                    I have a FULLHD tv so what happens when I start a 1080p movie? Will my stick first "down scale" to 720p and then up scale to 1080p?
                    /Fredrik
                    MK809III RK3188-T AP6210 running Neomode 3.1
                      /Fredrik
                      start antutu app test and you will see a real resolution of your screen
                        Just a quick question.
                        This talk about 720p and 1080p, is it possible to have real 1080p, Full HD, without making Density in the BuildProp from 160 to 240 or else. When we make that it is obvious upscale and not real Full HD. I use MK802IV, new Wifi.
                        Neo, do you have some quick solution for this in the future versions. Thank you buddy, you are the one.
                          Everyone is talking about mk802iv, but neo didn't say that this is compatible, is it?
                          I'm waiting for a mk802iv version.
                            It works fine although the overclocking kernels are messed up .
                            Just install with the stock kernel and select the perimeter file you want.
                            Mk802IV Neomode 1.9a original rom 720p
                              Specifically what kernel used for MK802IV , new Wif.
                              For version Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
                                The default one so nothing to change there.
                                Only thing you need to select is the perimeter file as a mentioned. (2g ,4g 6g are all included)
