Someone tested this ROM in the CX-919 models or BT-919? Did it work?
Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
Hey!
Hi everyone. Before asking something, I want to say "Thank you" to neomode for good work.
I am trying to use opera dvbs1 with android mk809 iv stick. I build every module for dvb support on mk809 iv kernel 3.0.36+. It did the trick and my stick detected usb dvbs. But it shows an error like below.
Code:<6>[ 81.265279] DWC_OTG: ********soft connect!!!****************************** *********** <6>[ 81.271268] DWC_OTG: USB SUSPEND <6>[ 81.371579] DWC_OTG: USB RESET <6>[ 81.395377] android_work: sent uevent USB_STATE=CONNECTED <6>[ 81.428144] android_usb gadget: high speed config #1: android <6>[ 81.428493] android_work: sent uevent USB_STATE=CONFIGURED <6>[ 134.017489] dvb-usb: found a 'Opera1 DVB-S USB2.0' in cold state, will try to load a firmware <6>[ 134.030687] dvb-usb: downloading firmware from file 'dvb-usb-opera-01.fw' <6>[ 134.030753] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xdb9bfd3f <3>[ 134.030805] dvb-usb: could not stop the USB controller CPU. <6>[ 134.030840] DWC_OTG: dwc_otg_hcd_urb_enqueue urb->transfer_buffer address not align to 4-byte 0xdb9bfc35 <3>[ 134.030899] dvb-usb: error while transferring firmware (transferred size: -1, block size: 16) <3>[ 134.030943] dvb-usb: firmware download failed at 21 with -22 <4>[ 134.031030] opera1: probe of 2-1.4:1.0 failed with error -22 <6>[ 134.031331] usbcore: registered new interface driver opera1 root@rk3188:/system/lib/modules #
Or may be a kernel with dwc_otg fix. Thanks!
Originally posted by popeye View PostAfter flashing, wifi-bt does not work, trying to flash a kernel to replace, but recovery button does not work anymore. Lappy does not detect stick when plug into usb.
What do you do when the reset button stops working, in such a case?
Depending on chip you will have to figure out which pins should be shortcut
Edimax wifi module with mk802IV
Hi... I`ve started using my Mmk802IV again, had to moved it so I can`t use my powerlines any more.
I want to you use my Edimax nano wifi module ( because the wifi on it is crap ) Can anyone point me in the direction of what to do? I`m pretty handy with the OS.. but I don`t know what I need and where to put drivers etc..
thanks
Yes, it works like a charm. In fact , if Im not wrong S400 is actually a 809IV.
BTW I would like to ask which kernel best suits for this model. Does the default kernel for this ROM include the shutter fix?
Thx
Originally posted by Starc86 View PostHi i have a Question i have Buy a Cozyswan S400 but it looks like the same Board MK 809 iii
The Board is a CYXTECH RK3188 909 V1 1 with AP 6210
Can i use this Neomode Rom for me ?
There are currently 2950 users online. 0 members and 2950 guests.
