Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
    Originally posted by ikerg View Post
    Does anybody know if I can use Google now over the stick if I connect the stick as a Bt phone over a car head unit?
    My appradio3 shows "voice recognition) but nothing on the stick side.I have ticked on the offline voice recognition (i tried with wifi tethering as well but with non success) and the use Google now with Bluetooth headsets
    Enviado desde mi GT-I9300 mediante Tapatalk
    Same here! How i disable?
    Many thanks!
    Edit: Just install other keyboard.
      I do not get this ROM running.
      I am able to flash without any problems but attaching the device to the TV nothing happens any more...
      Do I have wrong chipset inside my MK809iii Android 4.4 stick?
      On the board I see the text:
      CYX_809III
      V5_1 20140726
        got the same one, can't get it to work
        CYX_809III
        V5_1 20140726
          seems theres an awful lot of issues being reported but no answers :-( thats not good as was going to flash this on my 809III
            The problem is the mk809III.
            There are tho many different versions out there and not all are like the original one.
            But I will try to make a new one.
              Originally posted by neomode View Post
              The problem is the mk809III. There are tho many different versions out there and not all are like the original one. But I will try to make a new one.
              Thank you I have the 809 III with AP6210(don't know if its the T version or not) is there a safe option to flash ie one that will work with mine...???
                Yes then it should Work for you.
                This seems to be original.
                Also you can try the kit Kat kernel's from d33
                  Yes then it should Work for you. This seems to be original. Also you can try the kit Kat kernel's from d33
                  D33????
                    Look in RK3188 Thread there you find a thread kk kernel's for all devices. There you can download OC kernel's.
                      thank you for the advice and help.... very welcome indeed
                        lohtse let us know if you find the one working on v5_1 please
                          not sure what you mean but got if working perfectly on our 809III.
                            oh sorry, i meant MTrumml with his cyx809 v5_1
                              hmmmmmm starting to get random reboots after about 2 hours of use!!!!
                                probably an overheating problem if it's an OC kernel
