Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
Originally posted by Lucid View PostThanks NeoMode for bringing us new ROM's.
I really wish I found someone who got a touchscreen to work.
Slopert any Luck? I have a Lyama 27"
A 27 inch touchscreen and I can't touch it...
I got my touchscreen working. I use the 23" Hannspree HT231. I need to compile my own kernel but it works. You can check out my blog: http://gianttablet.blogspot.com
MK809IV and Neomode Custom Rom?
Hello @Neomode : Is there a custom rom planned for MK809IV (http://img.td-imgs.com/images/26/03/...TTH-252603.jpg)?
MK809III flashed. Wfi/BT doesn't work (Cannot be turned on). But USB ethernet works.
With USB hub, using wireless mouse and separate wireless keyboard, system hangs.
Fine when using either one singledly.
Any solutions or kernel I shd flashed instead?Last edited by popeye; 21 October 2014, 15:56.
Originally posted by Lucid View Posthttp://www.freaktab.com/showthread.p...24-quot-liyama
I am running a Neomode Rom already on my stick, if there's a patch that would be great,
On the other hand, I would not mind reflashing my stick completely, I'd LOVE TOUCHSCREEN !
and yes, it's a 24 inch, not 27, and it's a three year old one. Not the latest model.
Thanks for your qiuck reply !
If I recall correctly, that screen uses either a Qisda ar a Pixart touch interface.
I guess it's a Pixart, the Qisda one was one of the first to market. I tested with a T2250 monitor and that works out of the box.
Ven_id: 093a dev_id:8002
Originally posted by t_gumienny View Posthello
I have problem on this firmware on my device mk809iii ap6210 chip.
No sound (audio) on hdmi on my old TV, when i flash android 4.2.1 sound is ok.
When I put tv stick (firmware 3.1) to another tv sond is ok?
whats wrong?
pleas help
Otherwise, you can install Smic's version of kitkat on this forum. He provides a kernel option with the sound fix.
There are currently 5562 users online. 2 members and 5560 guests.
