Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
Originally posted by t_gumienny View PostPolloLoco can you give me link to rom with sound fix - work on mk802iv or mk809iii whit ap6210 wifi chip
I recommend that you help yourself so you know where to find these roms in the future. Click on the "MK Models" link at the top. IE - the same forum where you found this ROM. Smic's rom is stickied 2nd from the top. Just reading the first post in that thread will verify what devices it works for and that the sound fix is in place.
@Neomode : I tried booting the stick (i'm the guy with the Liyame Prolite T2452MTS)
but it won't boot anymoreIt keeps hanging at the loader screen 1.7 neomode custom ROM.
I'm going to have to flash a new ROM to get it working again I am afraid.
So If you could please wait a little longer for the output you asked (from the USB port) please do.
I don't think I ever managed to get a CWM recovery installed, that is too bad 'cause I can't hard reset now, can I?
I keep chasing the dream of having a 24 inch touchscreen tablet
Does anybody know if I can use Google now over the stick if I connect the stick as a Bt phone over a car head unit?
My appradio3 shows "voice recognition) but nothing on the stick side.I have ticked on the offline voice recognition (i tried with wifi tethering as well but with non success) and the use Google now with Bluetooth headsets
Enviado desde mi GT-I9300 mediante Tapatalk
CIFS
Originally posted by neomode View PostMax 1.7 GHz Stock GPU and DDR667.
Should work without Cooling.
Neomode
-AaronTronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
I tried to upgrade it.
What I've done:
1.Driver intalation
2.Run ROM FLASH TOOL
3.Plug in mk 809III
4.Erase IDB
5.Run
11:11:29 496 Load Setting ok
11:11:29 536 Neomode Rom Flash Tool v1.3.7.0 Start Run
11:11:29 536 Scan thread:14248
11:11:29 546 Infothread=11100)IoControlProc-->DeviceIoControl In
11:11:29 546 Infothread=11100)IoControlProc-->DeviceIoControl Out,ret=1,err=183
11:11:29 546 Infothread=9684)IoControlProc-->DeviceIoControl In
11:11:29 546 Infothread=9684)IoControlProc-->DeviceIoControl Out,ret=1,err=183
11:11:29 546 Infothread=14332)IoControlProc-->DeviceIoControl In
11:11:29 546 Infothread=14332)IoControlProc-->DeviceIoControl Out,ret=1,err=183
11:11:29 546 Infothread=11220)IoControlProc-->DeviceIoControl In
11:11:29 546 Infothread=11220)IoControlProc-->DeviceIoControl Out,ret=1,err=183
11:11:29 556 ProcessID:1592,ThreadID:14424,RefCount:0
11:11:29 556 ProcessID:1592,ThreadID:14248,RefCount:0
11:11:29 556 ProcessID:1592,ThreadID:11100,RefCount:0
11:11:29 556 ProcessID:1592,ThreadID:9684,RefCount:0
11:12:16 759 Info:wait for exiting scan thread start
11:12:16 829 Info:wait for exiting main thread start
11:12:16 839 ProcessID:1592,ThreadID:14424,RefCount:0
11:13:06 445 Load Setting ok
11:13:06 495 Neomode Rom Flash Tool v1.3.7.0 Start Run
11:13:06 495 Scan thread:824
11:13:06 495 Infothread=12308)IoControlProc-->DeviceIoControl In
11:13:06 495 Infothread=12308)IoControlProc-->DeviceIoControl Out,ret=1,err=183
11:13:06 495 Infothread=3552)IoControlProc-->DeviceIoControl In
11:13:06 495 Infothread=3552)IoControlProc-->DeviceIoControl Out,ret=1,err=183
11:13:06 505 Infothread=11888)IoControlProc-->DeviceIoControl In
11:13:06 505 Infothread=11888)IoControlProc-->DeviceIoControl Out,ret=1,err=183
11:13:06 505 Infothread=11088)IoControlProc-->DeviceIoControl In
11:13:06 505 Infothread=11088)IoControlProc-->DeviceIoControl Out,ret=1,err=183
11:13:06 515 ProcessID:15068,ThreadID:9328,RefCount:0
11:13:06 515 ProcessID:15068,ThreadID:824,RefCount:0
11:13:06 515 ProcessID:15068,ThreadID:12308,RefCount:0
11:13:06 515 ProcessID:15068,ThreadID:3552,RefCount:0
11:13:41 142 INFO:Start to erase IDB
11:13:41 142 INFO:Start to lower format
11:13:51 154 INFO:Lower format OK
11:13:51 154 INFO:Erasing IDB OK
11:13:52 982 Image Thread Path(\\?\USB#VID_2207&PID_310B#6&2CAE7568&0&2#{a5d cbf10-6530-11d2-901f-00c04fb951ed}),ThreadID=13624
11:13:52 983 INFO:Start to test device
11:13:52 984 INFO:Start to run
11:13:52 986 INFO:Test device OK
11:13:52 989 INFO:Start to download file
11:13:52 993 INFO: Start to download files to flash,backup offset=0x20000
11:13:52 995 INFO:Flash Start to download file to flash
11:13:53 020 Info:RKA_File_Download start,file=misc,offset=0x2000
11:13:53 030 Info:RKA_File_Download start,file=kernel,offset=0x4000
11:13:54 338 Info:RKA_File_Download start,file=boot,offset=0xa000
11:13:54 478 Info:RKA_File_Download start,file=recovery,offset=0x10000
11:13:56 062 Info:RKA_File_Download start,file=system,offset=0x282000
11:15:01 928 INFO: Download files to flash finished,Total(568994781)B
11:15:01 928 INFO: Start to check data
11:15:01 928 INFO:Start to check download data
11:15:01 959 Info:RKA_File_Check start,file=misc,offset=0x2000
11:15:01 959 Info:RKA_File_Check start,file=kernel,offset=0x4000
11:15:02 530 Info:RKA_File_Check start,file=boot,offset=0xa000
11:15:02 602 Info:RKA_File_Check start,file=recovery,offset=0x10000
11:15:03 421 Info:RKA_File_Check start,file=system,offset=0x282000
11:15:36 636 INFOownload file OK,Elapsed(103647MS)
11:15:36 640 INFO:Run OK
Looks ok but my TV dosn't see it, what is wrong ?
I cannot use Switch in that tool, I see this information "device can not do flash mode because it is not msc device" - It may be a problem ?
Some findings
My first post to these forums:
Thank you Neomode and all the ROM-Cookers for supporting us!
I just flashed your 3.1 ROM with 2GB Parameter to my Stick.
R-Box MK809 III 3188T with AP6210.
It is fast and beautyful but I have the findings stated here:
- Reboot is not working but starting it prevents all kind of shutdown of the stick (only possibility to pull the cord),
- Chrome flashes a red border (I read that strict mode should be disabled but is not enabled at all, build.props hacked but no use either)
- Pages in Chrome are falling apart, maybe I upload a screen later.
- No way to mount CIFS (already in the thread, yeah I saw).
- Screen scale problem (I read, that there is a solution, I will look into it)
Everything else just looks fine to mee, no one could done it better only other.
Kind regards,
Peter
Kind regards,
Peter
There are currently 3301 users online. 0 members and 3301 guests.
