Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
Originally posted by ataroshe View Post
Originally posted by m4f1050 View PostI have 2 of these and 2 with the Mediatek, these work perfect. You can get the 1080p, o/c and working wifi/bluetooth from another post "Kitkat kernel for all (well almost)" and pick AP6210-alt works 100%. Also, don't forget to wipe IDB and flash with stock recovery so it formats your DATA/CACHE/SDCARD, then you can flash TWRP or CMW. And to go into recovery on first boot, MISC partition - it wont clear data/cache/sdcard, only on stock recovery partition.
Maybe You can recomend something else? Because still can not boot.
Many thanks in advance.
Originally posted by ataroshe View PostUnfortuately it doesn't boot with AP6210-alt ("Kitkat kernel for all (well almost)") also - it stops on Google TV screen. Also it is veeeery hot. But I tried SD version of "Kitkat kernel for all (well almost)"
Originally posted by PolloLoco View PostIt's just a guess, so it may not work. Try Smic's 1080p ROM and kernel. I had 2 sticks which wouldn't boot with D33's kernels, but the Smic rom and stock kernel worked fine. I had 4 others (RK3188T) that I installed Quickshot 3.1 on.
Originally posted by m4f1050 View PostI guess they went crazy with the RK3188 MK809IV variants! Wow.. I know of 4, but God knows how many more variants are there! Jeez! No wonder the chefs are looking another way... LOL
Originally posted by PolloLoco View PostAgreed. Though they got real cheap, without knowing which sticks will be compatible with kitkat, I would never recommend buying an MK809III either. I'm just lucky I found good 1080p roms for the 6 sticks I bought.
Problem with usb Lan adapter with
Hello...
I have this rom on my hdmi stick...
now i have a problem...
i have a usb lan adapter and when it is plugged in (with usb) and the lan cable ist plugged in, the hdmi stick will not boot...
when i make the usb lan out, then boot the stick normal.
in android i can plugged the usb lan adapter without problems in.
sorry for my badness englisch
thanks for help...
Re: Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
thanks for help...
Two questions:
Are you using the factory power supply that came with the tv stick? If so, purchase a higher quality psu as strong stable power supply is necessary for the stick to carry anything but a kb dongle plugged into the device usb and still have full power to operate.
How does the stick function when the ether adaptor is plugged into a powered usb hub and not directly connected? Even with a good psu on stick the ether adaptor may draw too much current for the stick to operate normally on boot. Factors such as length of ethernet cable can also be a factor, as longer lengths of any cable will consume power in transition of data, causing attenuation or signal strength loss directly to conductors in cable and connections.
Incidentally, what is the brand and model of ether to usb are you using? They are all definitely not the same in chipset or general quality.
Hope that helps....
Sent from my SGH-I337M using TapatalkPlease post your h/w & s/w as signature to help community with troubleshooting problems.
Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
Originally posted by mechaone View PostUsb to ethernet devices pull quite a bit of power to function normally. There is a chance the device won't boot due to insufficient current.
Two questions:
Hope that helps....
1amp powered hub with a wired ethernet adapter (Trendnet TU2-ET1000) and a Logitech Wireless KB dongle. No matter what i do it absolutely will not boot with the ethernet adapter plugged in. It will also freeze the startup if i plug it in halfway (for example if i plug it in after the kitkat logo, it will stop and not bring up my desktop untill it's unplugged). Could it still be running out of power even with a powered hub? I have thought of experimenting with a usb3 powered hub with more current but they are expensive if its not a power issue
USB 3.0 hubs and devices are backwards compatible with 2.0 but arent worth the money for performance sake, as the RK3188 doesnt support 3.0 bus speeds anyway. I wouldnt purchase one when a decent psu will do nicely.
That aside, I'm sure it isn't an amperage bottleneck issue affecting you or the ether adapter wouldnt hang the system when plugged into a powered hub. The TU2-ET100 carries an Asix AX88772 chipset which should be compatible with most newer roms. At this point I'm out of my element and with what I've read elsewhere it seems the issue could be with the kernel. I didn't run NCR 3.1 for long before switching back to NCR 1.9a and cant remember all issues posted in this thread. Unless you have already done so, I would skim through the posts for anything relevant.
Are you both using the default Neomode 3.1 kernel? If so, I would try D33's kernel builds to test if that is a fix.
impossible to install the ROM 4.3 on MK809III (RK1388/MT3921SA/MT6622N)
I've tried to install the last NEMODE 3.1 ROM on my new device but I need a kernel for MK809III (RK3188) with MEDIATEK MT5931SA / MT6622N wifi/bt chipsets bought on dx.com
Can anyone help me ?
Cray
Well - as there are like a thousand different MK809III - please comment which chipset for WiFi and BT you have on your board.
Perhaps some kind guys can help you than with any working ROM.
Sent from my HP EliteBook 6930p using TapatalkKind regards Snuffy
HotLinks: MK918 Stock Rom Collection // Q7 Stock Rom Collection
Fixing the always changing MAC address issue
There are currently 2605 users online. 1 members and 2604 guests.
