Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
    Originally posted by guy123 View Post
    we speak about ram not nand.. the big chip on the board is nand, ram chips are smaller
    I understand, I said flash (not RAM) flash is usually nand. What I am trying to say is that 1GB RAM should be enough with this ROM. What you should really worry about is NAND where internal memory will come to play and where all your install and cache reside.
      Re: Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
      Sorry for this nooby question but what is then meant by 2gb ram/8gb rom? In antutu it states only 1gb. Basically I only need this stick for xbmc. Is 1gb sufficient?
      Verstuurd van mijn P6-U06 met Tapatalk
        Originally posted by neomode View Post
        Hello Guys,
        Here it is the New Neomode Custom Rom for the MK809III with Android 4.4.2.
        Have Tested this Rom and everything Works like it should with MK809III Version 2 & 3.
        The Rom comes with a SD Kernel and a DPI Setting of 160 and is Rooted.
        What Works ?
        - WiFi
        - Bluetooth
        - Rotation
        - USB
        - USB OTG
        Software Included:
        No-Frills CPU Control
        Reboot App from Petrus
        SuperSU (Root Access)
        Terminal Emulator
        FX FileExplorer
        Chrome
        Chrome UA
        This Time the Rom has a Lot of new Features:
        Volume Slider Works
        Added Power Down Button to Navbar
        Hide Navbar Button (Re enable it with Sliding from Top to Bottom)
        5Point1 Multichannel
        HDMI Passthrough
        OC Kernels Included
        (To Flash a OC Kernel press the Button in RKFlash Tool where Kernel is then you can Selec New Kernels from OCKernel Dir.)
        1,2,4,6 GB Parameter Files Select before Flashing
        Download:
        New Version:
        Upload running please wait 1h.
        Old Version:
        Regards
        Neomode
        hi neomode, I got your rom and I have these problems
        the rom works but no wifi and bluetooth
        what can i do
        809 rk mk iii rockchip 3188-t
        ccau33gc 1409
        wifi is :
        Realtek RTL8723BS Wireless and bluetooth
        thanks
          I also get confused by the terms. I call ROM the OS I install on the stick. But ROM is really "Read Only Memory" and RAM is "Random Access Memory" but I most cases we call a ROM what we install on the devices. And RAM the memory it has like the ram in a PC. And Nand (or Flash) memory is like your Hard Drive on a PC. At least that's how I see it. Anybody is welcome to correct me.
            ASIX AX88772B
            Hello...
            Can you integrate a driver for the ASIX AX88772B usb2lan adapter
            Thank you
              what can i do
              ccau33gc 1409
              wifi is :
              thanks
              I have the same unit. There does not appear to be and custom ROM for this unit yet. Any word on when this might be available Neomode?
                AW: Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
                Take it with this.
                Neomode
                  Hello, I am looking for Custom Rom MK809III-RTL8723BS Realtek Wireless and Bluetooth
                    lol....
                      lol....
                      Heheh
                      Sent from my iPad using Tapatalk HD
                        This is the next on the List.
                        Neomode
                          MK802IV WHEN?
                          Neomode
                          NeoMode please in this post you were saying you were making a version for MK802IV with AP6210, but I've seen the 3.6 gained for the old wifi.Cuando going to perform the upgrade for Kit Kat MK802IV with wifi ap6210?. Thank you work and excuse my English.
                            I'm willing to make a KitKat rom for RTL8723 wif if someone can donate me a device.
                              Same request: Custom Rom MK809III-RTL8723BS Realtek Wireless and Bluetooth
                              Neomode
                              First of all,
                              THANKS to Neomode for all his great work.
                              I (and I think a lot of other people around) really appreciate your effort and competencies.
                              I Installed this Rom (Neomode Custom Rom MK809III Version 3.1 Android 4.4.2) and everything is working well (Full HD too).
                              The only thing I'm still not able to start is wifi (I'm on RTL8723BS), bluetooth seems to work (I used a bluetooth keyboard to test the installed ROM).
                              I'll will wait for the forecasted new release and thank in advance for the help.
                              C1b10
                              Device: MK 809 III Quad-Core
                              Chip: Rockchip RK3188-T CCAU
                              33GC 1409
                              WiFi: Realtek RTL8723BS (wireless & bluetooth)
                              __________________________________________________ ______________
                              Everything should be made as simple as possible, not simpler. (A. Einstein)
                                Hello, can anybody explain the differences between all kernel files? I'm really confused!
                                Thanks.
