Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
Originally posted by neomode View PostNope I have released yesterday a new Rom for MK802IV Old Wi-Fi.
Next Rom will be AP6210 Wi-Fi Version.
Regards
Neomode
Sent from my GT-I9305 using Forum Fiend v1.2.8.
Re: Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
Regards
Neomode
Sent from my SGH-I337M using TapatalkPlease post your h/w & s/w as signature to help community with troubleshooting problems.
Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
Originally posted by sudros View PostJust out of curiosity, how is the Rom for the 809iii you picked up with the RTL8723bs wifi chipset going? I am so looking forward to that. Be nice to actually have my wifi working with a newer OS version. Thanks for all your great work.
Hi all.
First of all, thanks Neomode for the ROMs for our devides, that is an awesome work.
I am testing this rom in my MK809III device. it booted as it should, but it seems my wifi doesn't work. I go to the "about device" and it says "baseband version unknown". Means that I need to test other ROM? Is my Wifi chip wrong?
Any help would be more than welcome.
To all having issues with webcam dark video/image, I recently discovered that Exposure Compensation now has to be used in KitKat or you get dark video/image. Before in Jelly Bean a 0 value was ok and webcams worked OK, now I had to set my Exposure Compensation to the max (3 in the program im using) and requested the developer of the app to add 4 and 5, since it's still a bit dark and it wants to correct lighting by darkening even more. Just FYI... If the app doesn't have Exposure Compensation I would suggest you contact the developer of the app so they can add it to correct this issue. Using this rom, I have everything working great! Thanks Neo!
walter77 has fixed this issue in his roms by using a newer hdmi driver. Maybe neomode could use the same driver in his next release.
Originally posted by m4f1050 View PostTo all having issues with webcam dark video/image, I recently discovered that Exposure Compensation now has to be used in KitKat or you get dark video/image. Before in Jelly Bean a 0 value was ok and webcams worked OK, now I had to set my Exposure Compensation to the max (3 in the program im using) and requested the developer of the app to add 4 and 5, since it's still a bit dark and it wants to correct lighting by darkening even more. Just FYI... If the app doesn't have Exposure Compensation I would suggest you contact the developer of the app so they can add it to correct this issue. Using this rom, I have everything working great! Thanks Neo!Last edited by noobx; 01 July 2014, 10:36.
Regards
Neomode
Thanks Neomode
Sent from my iPad using Tapatalk HD
So, after reading all theese posts I'm a little bit confusing:
some people said they use to install this ROM on MK802IV new chip WiFi version AP6210 (mine model too) but Neomode said "next ROM will be AP6210 WiFi version.....". So guys......please tell me......I can install this ROM or I have to wait next from neomode? Thanks in advance
Originally posted by jordantheripper View PostSo, after reading all theese posts I'm a little bit confusing:
when the next AP6210 version will be ready i'll defiantly give it a try.
you can install this version with d33 kernels
on the kernel choosing, only the 4.1 no gpu worked for me.
Originally posted by aracy View Posti installed this version on my MK802IV and everything works great..
on the kernel choosing, only the 4.1 no gpu worked for me.Mk802IV Neomode 1.9a original rom 720p
There are currently 1782 users online. 0 members and 1782 guests.
