Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
    Originally posted by cray1903 View Post
    Me again,
    I've put my device in Mask mode but I need an update.img file of the ROM to complete the repair.
    Can anyone can send me a working ROM to use on my stick ?
    Even a lower Android version.
    MK809III (RK3188 + MEDIATEK MT5931SA & MT6622N wifi/bt chipset)
    Thanks.
    Cray
    You need to install NCR MTK ver 1 (or CS928 ROM for Mediatek chipset from Tech1) and if you want 1080p and overclock kernel you need to install d33's version 4.25 for mediatek on any of those 2 ROMs. You can PM me if you need the CS928 stripped ROM from Tech1.
      MK809 III B
      Hello for all,
      I have MK809 III B, will this rom work with that?
      Thank you
        Originally posted by PolloLoco View Post
        It's just a guess, so it may not work. Try Smic's 1080p ROM and kernel. I had 2 sticks which wouldn't boot with D33's kernels, but the Smic rom and stock kernel worked fine. I had 4 others (RK3188T) that I installed Quickshot 3.1 on.
        The kernels I build override the limits placed on the performance of the RK3188T SoC. A key part of this is to force the T chips to use the PLL clock for RAM and GPU timings. Stock code detects the T and switches to GPLL as some Ts have unstable PLL.
        If you have a 'good' T then all will be well and it will perform like a non-T, if you have a bad one it may get hot / not boot.
        I did build a CPU overclock only variant that allowed a little performance improvement whilst still switching to GPLL. I may get round to doing one again, but given that there are now 9 wifi chipsets and 4 variants per chipset I doubt it!!!
        Donate to Finless
          Mine...
          Hi everyone...
          I have a MK809III with RK3188T and RTL8723BS, will this ROM work for me... thanks...
            I understand that, but the irony is that the 2 that didn't work with your kernel were true RK3188's. Not T. I attribute it to one of the other hardware differences that neomode identified. The 4 that are working phenomenally with Quickshot 3.1 and your kernel are RK3188T. All 6 were running at 1.6ghz via benchmarks.
            I love your kernels, but I might recommend Smic's if yours won't boot.
              Oh, how odd! What are the differences and I'll see what I can do
              I know I can't force PLL sync with VMAC Ethernet compiled in. The kernel doesn't boot so it may be something similar
              Donate to Finless
                Originally posted by mechaone View Post
                USB 3.0 hubs and devices are backwards compatible with 2.0 but arent worth the money for performance sake, as the RK3188 doesnt support 3.0 bus speeds anyway. I wouldnt purchase one when a decent psu will do nicely.
                That aside, I'm sure it isn't an amperage bottleneck issue affecting you or the ether adapter wouldnt hang the system when plugged into a powered hub. The TU2-ET100 carries an Asix AX88772 chipset which should be compatible with most newer roms. At this point I'm out of my element and with what I've read elsewhere it seems the issue could be with the kernel. I didn't run NCR 3.1 for long before switching back to NCR 1.9a and cant remember all issues posted in this thread. Unless you have already done so, I would skim through the posts for anything relevant.
                Are you both using the default Neomode 3.1 kernel? If so, I would try D33's kernel builds to test if that is a fix.
                Sent from my SGH-I337M using Tapatalk
                I'm using D33's kernel_v4.1_TVSTICK_AP6210_HD.img, I actually never tried the default kernal, perhaps daki1978 has and can add their thoughts. I think that you are right that it could be a compatibility issue with the ethernet, I did skim through this thread but didn't see anything about this particular problem. I guess I'll live with it until the next ROM
                  I've been trying to find the Neomode thread which highlighted the different boards for the MK809III, assigning different compatibility to each. I haven't had any luck in the last half hour or so.
                  I definitely wouldn't consider this worth spending your effort on. I no longer own the 2 RK3188 sticks that didn't work with your kernel - I had bought the group of 6 to give to my groomsmen when I got married in June. I could open one of them up when visiting the friends that own them, but since I found a fast 1080P kitkat rom that works - I don't think you should spend your time looking at it. For about 2 months, however, I was wishing all of my sticks were RK3188T. :-)
                  I've just used this experience to explain to folks why the freakbox project is a great idea, especially at the new price point. I don't need an RK3188 box - but I'm tempted nonetheless. If freaktab does the same with the RK3288, I'm definitely buying one.
                    Worked like a charm.
                    I was about to through it away
                    Thank you so much.
                      Thank you so much.
                      REMEMBER: If you run an overclocked and/or 1080p kernel you *MUST* have the CPU thermally protected.
                        MK809 III with Mediatek MT5931 & MT6622 Wifi/BT Combo. Issue
                        Hello!
                        I have MK809 III with Mediatek MT5931 & MT6622 Wifi/BT Combo.
                        Please give me a link to Android ROM for this product!
                        Please reply!
                        Thank you.
                          Originally posted by Mundyna View Post
                          Hello for all,
                          Thank you
                          Depend on the Wifi chip but that was the name of mine from dx.com
                            It's the same I got.
                            Go to the previous page http://www.freaktab.com/showthread.p...l=1#post215704
                            It worked for me.
                            Originally posted by miclmr View Post
                            Hello!
                            Please reply!
                            Thank you.
                              Hi all.. Hoping someone knows the issue.
                              I had this rom on my MK802IV for a while.. Then I tried finless.. Now I'm back to using this rom. Been pretty good apart from having to change the sound after each reboot etc..
                              But I've got a weird error. Mostly when I install from the play store, but sometimes when I install from my apk folder.. I get error 42, or trouble parsing package or it goes through the install then at the end says " not install"
                              Any I looking at an issue with the storage? Or what? This time I used the 4gb parameter file..
                              Sent from my iPad using Tapatalk HD
                                Have you tried changing default install location?
                                Code:
                                [COLOR=#222222][FONT=inherit]pm set-install-location 0[/FONT][/COLOR]
                                0 = auto
                                1 = internal
                                2 = sdcard
