Oh can I do this in a terminal? or something else??
Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
*Just an issue*
Hi Neomode. Some time ago I wrote here because I had installed this update in my MK809III and wasn't working well untill you told me to use the power adapter that came with the device. And it began to work excellent. Now I just want to let you know that I found an issue (at least in my device). Every time I turn on the device, the screen is not at its full size. I use it in a led tv and I see black bars surrounding the image. So I go to the settings and change the screen size untill it covers all the screen. But when I turn it off, these settings go back to the previous state. So the next time, I have to change them again.
Thank you
Originally posted by m4f1050 View PostRead a few pages back, the solution is in this very thread. there is a displayd file you need to swap.
Not all here got coding chops and some are just experienced enough for rom flashing.Mk802IV Neomode 1.9a original rom 720p
Originally posted by Magnus33 View PostLikely a good idea for someone to upload a modded system file since some wont be able to copy it over.
Got one of these sticks coming soon Neomode , can't wait to try this rom. Something new for me to play around with, kinda bored with how unsmart my tv is.Last edited by Damo; 26 August 2014, 21:20.Please consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Originally posted by Nijaz View PostHello, how do I change the kernel? choose the program a new, flash, after reboot there is only one version of the frequency of 1.4GHz
After your done flashing and setting the rom location serives up.
Go back to the flash program and unselect everything except the kernel and on the right side of that click on the tab and browse to where ever you unzipped D33 latest kernel.
Select TV stick either hd (1080p) or sd (720p).
Put the stick back into flash mode and click run on the flash program.
Thats it its now good up to 1.6ghz.Mk802IV Neomode 1.9a original rom 720p
Netflix Reboot stick after some time playing
First I would like to thank neomode for this rom and d33 for the kernel.
My MK809III is running so good with the work of both.
But the only issue is with netflix. After sometime (about 40 minutes) he crashes and reboot my android stick. then start to reeboot with smaller time. Tested with others apps but crashes only with netflix.
Did someone have this issue? I tried others versions of this app but stiil crashed.
You can download no frills cpu controler and set it to run at a max of 1.4ghz and see what happens.
This way you get to use D33 kernel but reduce heat.Mk802IV Neomode 1.9a original rom 720p
Thanks for the tip Magnus33. I'll try the downclock process and post the feedback
UPDATE: It's seens that work well. I did the downclock to 1.2 ghz and played netflix 2 hours straight without reboot.
ThksLast edited by jirousbh; 27 August 2014, 14:26.
There are currently 5310 users online. 2 members and 5308 guests.
