Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
    Also missing is "WifiDisplay" app (I believe it was preinstalled on stock).
    or is there another app that can do Miracast on the 802III and 802IV?
      Seeing frame skipping in youtube and video corruption.
      Not sure if this a kitkat or rom issue.
      So far its seems to be older videos.
      Mk802IV Neomode 1.9a original rom 720p
        Hi, to everyone first, thanks to neomode for all his work.
        I Have received a MK809III with AP6210 and RK3188-T(a shame) I got 16600 on antutu, and it has wifidisplay app.
        Does this rom work well on my device?
        Can I overclocket it to 1.6Ghz?
        Does this rom has WifiDisplay app?
        What is aproximately the score for this rom?
        Thanks in advance.
          Thanks in advance.
          Since I installed this 3.1 ROM in my CX-919 with the full RK3188, I don't know the score for this ROM with the "T" version...
          However with FULL RK3188 I am getting 19477-19677 with Antutu, using the kernel_cpu1704h_gpustock_ddr667.img on my CX-919, and 1.7 CPU speed (1.2GHz Min-CPU/1.7GHz Max-CPU).
            Originally posted by Magnus33 View Post
            The logo is the a series of pics if its moving or if its not then just a static one.
            If you ask nicely and post a pic iam sure they can make you one in short order which you can load with room too kit or the like to any rom.
            Go to the boot animations section and ask tattman65 to do it he does awsome boot animations and sure he can hook you up.
              Thanks for your work Neomode!
              This time Full HD is working stable (my tv is showing 1920x1080@60, but the Android desktop size nevertheless is still 1280x720).
              I can remember in one of the previous ROMs 1080p was instable, but the android desktop had 1920x1080.
              Or can I modify the desktop resolution by myself?
              Greetings, -chris-
                @Neomode
                Neomode I hope you can help. Iv'e tried your 3.1 on my MK908 V5 but it doesn't work (no blue led) I think the MK908 V5 maybe different to other versions of the MK908 Iv'e tried other KK roms and all have the same result on my stick?
                The only rom that has worked for my stick so far is Finless 1.8 which isn't KK? I'm not sure what to try now.
                  Minor glitch in location services.
                  If you don't agree on first install to use them you can go into settings and turn them on later as this doesn't function.
                    Re: Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
                    Been searching posts n I cant find the relevant info. Can anyone confirm that the system volume bug was fixed? If so, Im flashing to my MK802IV immediately... Thanks guys.
                    Sent from my SGH-I337M using Tapatalk
                    *Edit* Derrrrr.... Sorry. Just went back to post #1 and found the obvious..
                    Please post your h/w & s/w as signature to help community with troubleshooting problems.
                    Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
                    uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
                    iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
                    Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
                      Quite by accident i discovered daydreams is actually still in this roms but there not actually control for it in display settings.
                      When i restored a backup made on finless beta days dreams kicked but there where no controls to turn it off..lol.
                        Problems with version 31
                        Hi Neomode, I've been trying to install this update but it keeps rebooting all the time. The KitKat logo appears for a second and then it reboots. A few times it gets to the main screen and I could config some of the settings but it reboots again. I don't know what to do. Do you think the next update will fix this'
                        Originally posted by neomode View Post
                        Hello Guys,
                        Here it is the New Neomode Custom Rom for the MK809III with Android 4.4.2.
                        Have Tested this Rom and everything Works like it should with MK809III Version 2 & 3.
                        The Rom comes with a SD Kernel and a DPI Setting of 160 and is Rooted.
                        What Works ?
                        - WiFi
                        - Bluetooth
                        - Rotation
                        - USB
                        - USB OTG
                        Software Included:
                        No-Frills CPU Control
                        Reboot App from Petrus
                        SuperSU (Root Access)
                        Terminal Emulator
                        FX FileExplorer
                        Chrome
                        Chrome UA
                        This Time the Rom has a Lot of new Features:
                        Volume Slider Works
                        Added Power Down Button to Navbar
                        Hide Navbar Button (Re enable it with Sliding from Top to Bottom)
                        5Point1 Multichannel
                        HDMI Passthrough
                        OC Kernels Included
                        (To Flash a OC Kernel press the Button in RKFlash Tool where Kernel is then you can Selec New Kernels from OCKernel Dir.)
                        1,2,4,6 GB Parameter Files Select before Flashing
                        Download:
                        New Version:
                        Upload running please wait 1h.
                        Old Version:
                        Regards
                        Neomode
                          AW: Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
                          I need to know which Device and wich Power supply you use. Because for me It works without Failures.
                          Neomode
                            Problems with version 3.1
                            Sorry Neomode, the device is MK809III and the power supply is the usb port in the tv.
                            It reboots all the time...
                            Thank you-
                            Neomode
                              Hi, any chance to see this for the MK802IV with AP6210 (new wifi)? Or can I use this one?
                              Gruesse aus Mexiko nach Deutschland!
                                Thank you-
                                Here We got the Failure! The usb Port if your TV gave you not the power that is needed. The usb Port give you as max. 500mA you need min. 2000mA.
                                Please use your power supply that comes with your Device!
                                Neomode
