Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
    CX919 no SD?
    Title of post is solved...SD card got corrupted for some reason and I didn't check it so dooooh...
    Thanks for the great rom!
    Using it with D33's v4 TV Stick SD kernel (cpu oc @ 1.8Ghz), working great on a CX919 (confirmed T chip).
    Also thank you D33 for your kernels, love em.
    Regards
      Originally posted by aracy View Post
      well thank you very much!
      the regular kernels didn't work, only the no GPU kernel worked.
      No prob.
      Yeah quite a few of the T versions don't like Gpu overclocking.
      Mk802IV Neomode 1.9a original rom 720p
        Regards
        Your are using the D33 v4.0 Kernel in your CX-919 without any extra cooling. Does the CX919 over heat or get any hot outside?
        I am asking because Magnus33 mentioned that:
        "They are CPU: 1.6 GHZ, GPU: 600 MHz, DDR: 720 MHz which is about as safe as you can do without extra cooling".
        I have noticed that all the NEW 33 v4.0 Kernes are 1.6 only... How you OC to 1.8?
          I have noticed that all the NEW 33 v4.0 Kernels are 1.6 only... How you OC to 1.8?
          It should get warm but no really hot and 1.6ghz is really the safest without added cooling.
          Besides after 1.6 the returns of overclocking rapidly diminish .
          Also many of these devices don't like gpu overclocking so there alternate kernels which don't overclock the gpu or both the gpu and ddr.
            AW: Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
            I Start to Work on Version 3.2.
            Any wishes from the Community for the next Version?
            Neomode
              Neomode
              Sharks with laser on their heads?
              I like to see the daydreams function restored since its useful for avoiding plasma burn in.
              Ohh the locations services could not be turned on in 3.1 unless it was done at the start otherwise it didn't function.
              Nice to see you back amoung the healthy
                Neomode
                Hi
                Q1: When I connect my stick with Bluetooth, in profile settings stick shows up as "Phone", is it possible to change that to "media" Hope you understand what I am trying to say??
                Q2: Permission issue, is it possible to change from "Enforce" to Permissive?, need that to have stick to work with touch on my Pioneer Appradio
                Basmand
                  Neomode
                  Smooth streaming Full HD 1080p/24p over LAN without stuttering! (still my stick mk809III can't beat my mede8er )
                  My Device: MK809III new Wifi Neomod Rom 2.0
                    Actually I've replaced the stock heatsink with a big heatsink and also added a heatsink to the ram.
                    I've attached a digital thermometer to the heatsink, it never get's above 58 °C, which is pretty hot but not alarming.
                    This is after some time of playing heavy 3D games, under normal usage conditions (XBMC etc) it never gets above 45°C.
                    EDIT: Done some testing and the temps appear to be much lower with this new rom/kernel combo.
                    While running XBMC it's around 36 °C, Antutu is at 43 °C at the end of the test.
                    Antutu score is 21000+ .
                    Not bad at all!
                    Regards
                      flashing mk809III with 3188T
                      Hi everybody)
                      I read the theme, but found just this way of flashing the Neomod ROM
                      But there is no instructions about how to flash it with another kernel for 3188T(do I need it or neomod 3.1 works with 3188T with its kernel?).
                      Can someone please explain to me what neomod 3.1 ROM (old or new version) and which kernel should I flash (and how) for my MK809III with 3188T and АР6210 wifi module?
                      Many thanks in advance)
                        Neomode
                        The only thing I can ask for is a 1080p version of this rom, with the same or better performance... Because this one is already close to perfection: no screen flickering (that happened with ALL the roms until this one) and smooth video playback. 1080p is the only thing that I am missing...
                        And welcome back!
                          Would like to keep this ROM, but Watchever app is not working. Only with 1.9 or Finless 1.6b. Connected HDMI problems.
                          gesendet von meinem Samsung Knochen
                            Neomode
                            Fixing the Screen Scale & Audio Output Device would be GREAT! Please.
                            Each Startup (Boot) Android doesn't remember Screen Scale and Audio Output settings.
                            Have to set it up each time i boot the device.
                            But this Rom is the fastest until now on my CX 919 Stick.
                              Finally spotted the problem I have with all kitkat roms on my CX-919 ap6210 -
                              only when changing system language to hebrew instead of english and rebooting causes the no navbar and blinking screen issues. after changing back to english the UI is reseting and I can change back to hebrew until the next reboot.
                              maybe a fix for that on 3.2?
                                could you change the mousepointer?! a normal will be fine.
                                for the hardcore-user a max oc 1080 will be nice.
                                dank dir für die arbeit.
